Results 1 to 5 of 5
Thread: iGuidance Won't Connect in Centrafuse 3.1
    Apr 2008
    If I run iGuidance outside of Centrafuse independently or in Road Runner, it runs fine. Connects to satelites and gets me going.
    But if I open Centrafuse 3.1, and using the FuseGuide plugin, start iGuidance, the arrow just stays silver. Tried using Xport to split Com ports but that didn't work either...
    Suggestions?
    Mar 2008
    The native NAV of CF (Destinator) might be using the same port - check the settings.
    I use XPort to split COM3 (where my GPS is) into COM6 and COM7. iGuidance uses COM6 (needs to be set in iG settings), Destinator - COM7 (need to be set in CF settings).
    Hope this helps,
    --max
    Quote Originally Posted by E92er View Post
    Suggestions?
    Apr 2008
    Great idea! Just went out and turned off Destinator and just to make sure, changed Destinator's COM to 8 since iGuidance uses COM 3 for me....still nothing.....
    Mar 2008
    Are you sure your GPS is on COM3? Sometimes it get's some other port. Check Device Manager.
    Do you have XPort running?
    Apr 2008
    If I start Xport, it shows up Green on COM3, I used to use Xport when using Roadrunner but with CF 2.1, found iGuidance worked fine without running Xport so I stopped using it....
  1. If you use Centrafuse 2 or 3 or 3.1
    By mitchjs in forum BoomzBox HD
    Last Post: 10-17-2012, 11:18 PM
  2. Centrafuse 3.1 Playlist Converter
    By PaulF in forum Software & Software Development
    Last Post: 03-14-2010, 06:16 PM
  3. Tired of "ABC" keyboard in IGuidance? iGQwerty
    By lostreception in forum GPS
    Last Post: 09-18-2009, 06:07 PM
  4. Replies: 1
    Last Post: 09-21-2007, 09:24 PM
  5. Replies: 32
    Last Post: 05-18-2007, 09:43 AM
