Results 1 to 10 of 18
Thread: Centrafuse 3.5 troubleshooting
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    Just installed CF3, still getting used to it. Wondering if anyone would like to shed some light on some of these issues im having with it.
    Settings > wifi shows my adapter but the "wifi app" shows "no wifi adapter found"
    bluetooth doesn't seem to work with my iPhone 4. It def. has a2dp but CF doesn't recognize it. Its paired with the phone just fine, and knows when im on a call - but audio doesn't come through that either. It seems blue solie doesn't seem my phone as having those capabilites so maybe blue solei doesn't support iPhone?
    the boomsbox is not recognized as a radio. Even though when choosing a com port for the obd2 it lists mitchMJZ boomzbox hd radio.
    the obd link is connected via usb and powered on - but no com port recognizes it.
    Why are gestures alpha based? That seems... not useful. Did you not build in normal left right up and down gestures?
    Other than that its really fast.
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    The lastest bluesoleil does work with iPhone 4. You have it to pair it first via Bluesoleil, then you load CF and configure it there. I tested, place and receive calls no problem, haven't test A2DP though. Make sure you selected the correct audio device in the settings (I think there is an audio device under BT and Phone, other than "general").
    I don't have Boombox or obd, I had it in the past, never had a problem. Same with wifi, I actually uninstalled the wifi app from CF, had no use for it, but it was working at the time.
    Hope this helps a bit.
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    Thanks - yea blue solei sees my phone, but it says it only has 1 service available which is the first one, i forget which that is. But it def. doesn't have the 6 the iphone is supposed to have. Maybe i have an old blue solei
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    ugh, 3.5 is so buggy, don't know why they released that ... im sticking to 3.1 for now.
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    3.1 was SO slow for me. Like - unusable. But 3.5 is instant. So - i'm ok working with the bugs and lack of apps for now. At least I got radio, music and tomorrow ill have GMPC working and hopefully bluetooth will work soon too. Then its all good.
    Dec 2007
    Danville, CA
    Yes, 3.5 is faster for me.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I'm not thrilled with 3.5 either. Seems they always take two steps forward, then change something else that makes it seem like one step back. I do like the Skin Editor software. I think finally I can get into skinning.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    Aug 2007
    Queens, NYC
    GMPC does not work 100% for 3.5 from what I read.
    faster is always good. but how much faster?
    did they fix the bluetooth issue where if you get a call CF would like freeze up for a few and nothing responds? or the one where CF always takes precedences of the call even though you choose to use the phone itself
    CarPc
    Project "Driver"
    Planning [99.9%]
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    well I haven't got bluetooth to work yet. So IDK. I have GMPC running but not in CF.
    Is it a known thing that HD radios often switch from HD to non HD?
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Frequent switching between HD and non-HD is a hardware and reception issue. There isn't anything in CF (or any software for that matter) that controls whether or not a signal is HD and can be received as such. The hardware determines that and notifies the software.
  1. Troubleshooting Noise
    By optikalefx in forum VaultWiki
    Last Post: 02-09-2011, 03:36 PM
  2. CD Rip troubleshooting help needed
    By overlander in forum RR Plugins
    Last Post: 11-04-2008, 09:04 AM
  3. need some help troubleshooting
    By S4Per in forum Power Supplies
    Last Post: 07-02-2006, 05:54 PM
  4. Any LCD Gurus Here? I need troubleshooting help!!!
    By WebGeek in forum LCD/Display
    Last Post: 08-05-2004, 04:09 PM
  5. help troubleshooting my lcd please!!!
    By Fiddler in forum General Hardware Discussion
    Last Post: 04-25-2000, 03:27 PM
