I'm not sure if Centrafuse ever supported the T3, it was before its time, but it definitely supports the Infill G4 through a special plugin app called "Infill", so if there are any similarities (common drivers) they might work for you.
Check out the Miscellaneous category on the CF Market - http://www.centrafuse.com/AppCategory.aspx?cid=4
There's a plugin called Infill that controls (on the G4) the volume/mute hw buttons, tilt/brightness controls (through the software plugin) and also is required to make the AM/FM radio work. AM/FM Radio module for Infill is a different donwload. For that see the Radios section of the Market.
Hope this helps.
LinkBack URL
About LinkBacks
