Results 1 to 4 of 4
Thread: Centrafuse System Temperature Reading...
    Dec 2010
    Ok so I have centrafuse 3.5 installed on 2 different laptops. I can click system and then system info and it tells me the temperature. On my netbook I saw the temp at 55 and another time it was around 60 celcius. My carpc uses a laptop and once I checked it said 62 and then later I checked it said 64 celcius. Today was a cold morning around 15 celcius. I boot up and check the temp it says 64? is this just reading correctly or does it refresh once a week? Any hints? or other software I should use instead to monitor the temp?
    Constant Bitrate meryan00's Avatar
    Feb 2007
    Indiana
    How long was your system running before you checked your temperature, and also what programs were running?
    If you had say, DVR, Centrafuse, GPS, and Radio programs/plugins then it is very possible that it was up to that temperate in under a minute especially if it is under a seat and the fans cannot move any air.
    Dec 2010
    It's in the trunk, I have a few usb items and plugins and I am sure it reached that temp but I guess it takes a while for centrafuse to update the info today after a 30min drive it said 47 degrees. I think it just updates it very slowly.
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Are you thinking that Centrafuse only updates that temp once ever so often and stores the data someplace? 'Cause that ain't how it works. The displayed temp is "read" when you click the system info button. Now I don't know which system sensor is actually providing the data (since Centrafuse is reading this from the bios/operating system), or how often that sensor updates, but Centrafuse doesn't store it anywhere for later use. It's completely dynamic.
    Cheers!
    VegasGuy
  1. Centrafuse not reading MP3 tags
    By FunkDaMonkMan in forum Centrafuse
    Last Post: 05-10-2011, 07:37 AM
  2. Temperature reading in Fahrenheit..How?
    By JohnWPB in forum Fusion Brain
    Last Post: 11-29-2008, 11:11 PM
  3. Outside Temperature reading
    By Civic03 in forum Software & Software Development
    Last Post: 08-07-2006, 09:30 AM
  4. DFI G5M100-N system temperature
    By backspace in forum General Hardware Discussion
    Last Post: 01-29-2006, 03:53 PM
  5. External temperature in Centrafuse?
    By justintime in forum Centrafuse
    Last Post: 10-20-2005, 03:01 PM
