Results 1 to 3 of 3
Thread: obd ii
    Dec 2010
    obd ii
    i am working on my project with centrafuse i ahve buy a elm327 to have the obd ii work i install drivers then set port in centrafuse and choose the elm 327 too but it wont connect do i need to do something else?
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Try setting the port speed to 34800. Also make sure "autostart" is on. restart Cf afteryou make the settings changes.
    VegasGuy
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    If it's a knock-off ELM327 from China, 9600 might be the port speed to try.
    Also, you probably want to confirm that the unit is installed correctly and the configuration is correct by trying a standalone ScanTool program.
    At least, that's what I do.
