Results 1 to 6 of 6
Thread: Auto-Tethering to iPhone when loading CF
    Dec 2007
    Mohnton, PA
    Let me start off by saying that I just migrated from RR to CF and I can't believe I didn't do it sooner. Just installed CF4 w/ nav this morning and I love that it auto connects to my phone and Bluesoleil will grab the contacts. It works great!
    That being said, I prefer to use bluetooth tethering (jailbroken running MYWI) instead of running an iphone USB cable to do it, and I am wondering if there is a way to have CF automatically initiate the tether (connection to PAN in bluesoleil). I can create a shortcut to launch the connection and drop it in my startup folder, but I prefer to have CF do it once the bluetooth drivers are fully initalized because sometimes the connection will launch before bluesoleil is up and running and the connection fails.
    Worst case scenario, I will just run a cable and plug the phone in for a usb tether.
    Thanks.
    Nov 2009
    Quote Originally Posted by phuz View Post
    Thanks.
    I first started with CF then to RR and now back to CF If you can find a way to autoconnect that would be amazing i cant seem to find a way. I currently just plugin in usb.
    What short cut are you putting into your start up folder?
    Mike
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Thanks.
    Unfortunately, CF doesn't support the BT PAN profile with BlueSoliel. For that matter, I haven't seen a whole lot of success stories about using an iPhone with BlueSoliel and Centrafuse period. Not too many happy folks. One possible workaround -since (to be brutally honest) your're not likely to get your iPhone working with CF and BlueSoliel, you can try using the PAN profile with BlueSoliel directly from the windows desktop, or you could try another BT stack that supports PAN profile. According to the IVT website (makers of BlueSoliel), they only support the iPhone2g....pretty lame, huh.
    VegasGuy
    Dec 2007
    Mohnton, PA
    I have the USB tether option enabled, so as soon as I plug the iPhone in, it's immediately on the internet. I can enable the PAN through a shortcut on startup, but I guess I was hoping to keep it all bundled inside CF. I have the iPhone working through CF as far as calling and contacts go. I'm not too disappointed with that, other than sometimes on a boot it doesn't connect to the phone and I have to reboot. Not sure what that is all about.
    Jun 2011
    Japan
    what version of Centrafuse and iPhone are you using?
    of me, does not work.
    Centrafuse 3.5
    iphone 4 iOS 5.1
    Bluesoleil 8.0.370
    Sep 2006
    The closest option I know of is MyWi ondemand but it only works with iPads. Perhaps you could contact their team and see if they can open up this feature. I too have been curious about an easier way to tether automagically.
  1. Iphone tethering keeps getting disabled
    By Goddy in forum Wireless Communications
    Last Post: 06-15-2010, 03:47 PM
  2. Iphone tethering
    By scatebase in forum iPhone and iOS
    Last Post: 04-02-2010, 02:36 AM
  3. Iphone tethering after 1.1.1
    By rotarypower101 in forum Wireless Communications
    Last Post: 08-28-2009, 01:32 PM
  4. iPhone usb tethering and vncviewer embedded
    By smp4488 in forum RR Skins
    Last Post: 03-13-2009, 11:08 AM
  5. iPhone now with tethering for mobile access
    By parksgm in forum StreetDeck
    Last Post: 08-08-2008, 08:11 PM
