Results 1 to 4 of 4
Thread: Display size
    Mar 2012
    Display size
    I am still in the middle of building my carpc, but I have the pc and touch screen ready to go. So far, I've decided to run with Centrafuse, but I'm having problems with the dispaly size.
    I don't know if it's because I am using the trial version or not, but the display only opens up at about 3/4's of my screen size. So you can still see the bottom portion of my desktop and my Windows Task Bar.
    I did set my resolution to 800x600, are there any other options/settings that I can mess around with? Or is this just the way the trial version runs?
    Jun 2011
    Japan
    Quote Originally Posted by romycha1 View Post
    I´m too...
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    I'm having the same issue...I have 8' screen, but this program seems to be set up to run on a 7" screen, so if an answer isn't given soon i will be removing centrafuse from my carpc.....good thing i am still only messing with the trial, cause i would have been mad if i already purchased, no lie!!!
    so far i have edited the xml file main screen to 800x380(the original setting was 800x480), and now it fills the whole screen, but some of the other screens are not displaying properly. my setup screen is not lined up, and i have no idea what to edit to fix it....sucks!!!
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
    VegasGuy's Avatar
    May 2009
    Las Vegas
    You guys probably ought to post this on the Centrafuse forum first, but the solution is simple.
    1. Open System->Settings. Make sure Advanced settings is selected.
    2. Select graphics and click setup
    3. in the upper right hand corner, click "Fullscreen"
    4. Save.
    That's it.
    VegasGuy
  1. Display size help req
    By sflowers in forum LCD/Display
    Last Post: 09-05-2010, 09:32 AM
  2. MI Display Size Locked, but Why???
    By DJ_SpaRky in forum Mobile Impact
    Last Post: 08-18-2007, 03:57 PM
  3. How to reduce the display size ...
    By JPMG in forum LCD/Display
    Last Post: 10-15-2006, 06:46 PM
  4. Display size
    By s1iderd in forum LCD/Display
    Last Post: 09-11-2005, 07:30 AM
  5. What size of char. display do U have??
    By DJ in forum General Hardware Discussion
    Last Post: 11-02-2000, 02:02 PM
