Results 1 to 3 of 3
Thread: Sound devices and such
    Jan 2012
    Alright, my setup is a bit unique to what many people are likely running. I'm using AudioMulch to do my crossover work, the problem is I need my default audio output to be through Virtual Audio Cable, but my volume control doesn't work through VAC, it works through a device called M-Audio Multichannel. So is there any way in a config file or something to set volume control to control a different device then what it's outputting through?
    Jan 2012
    Hah nevermind! I just figured out that in VAC there is a check box for volume control which enables volume to be controlled through the VAC device. Stupid me
    Jan 2012
    Ok, another issue though is that Centrafuse suddenly only wants to use one channel of audio? It was using 2 before....and everything else works just fine it's only Centrafuse? Hmm....
  1. Muting Other Sound devices on startup
    By rodweb in forum RR Bug Tracker
    Last Post: 05-28-2009, 06:33 PM
  2. USB devices help!
    By Focal in forum Newbie
    Last Post: 04-25-2007, 05:46 PM
  3. Two Sound Devices; 1 for output, 1 for input
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 07-29-2006, 07:56 PM
  4. $35 USB GPS devices
    By Will Albers in forum Classified Archive
    Last Post: 03-29-2006, 07:30 PM
  5. USB Devices = Always On??
    By KingsDude in forum Newbie
    Last Post: 02-22-2005, 05:38 PM
