windows 7 all versions centrafuse 4've tried but can not run
hardware-no place to write the articles do not appear, and most are blank
In this way at least 10 times re-installed windows
"A clean install of Windows 7 (x86 or x64)
⦁ Run Windows Update and install ALL updates and patches
Make sure ⦁ Windows 7 service pack 1 is installed
Make sure that ⦁. NET Framework 3.5.1 is turned on in Windows features
Install ⦁. Net 4.0 extended (full) framework
⦁ Install SQL Compact Edition 3.5 (x86, x64 if you are using the windows 7 64 bit)
⦁ Run Windows update again and install all updates and patches
⦁ Install IE9. It's not required for Centrafuse, but you'll keep getting asked about it so you might as well do it now.
⦁ Run Windows update one last time. "
What could be the problem?
Code:
error.log
04.01.2014 01:29:17 (29:17.43)
Index was outside the bounds of the array.
at e3FcvKnBTbWUnvsVaHm.e92hfvnwSAOAmBxqiia.CF_localsk insetup()
04.01.2014 01:29:17 (29:17.70)
at market.Market.CF_localskinsetup()
04.01.2014 01:29:17 (29:17.71)
at market.Market.eeZbTFBvf()
04.01.2014 01:29:18 (29:18.30)
Object reference not set to an instance of an object.
at e559oTaX5XZSq158ENG.eTNCQuafY5Ct54L90mE.ewyDv6kPtG ()
windows
Level Date and Time Source Event ID Task Category
Information 04.01.2014 01:30:33 VSS 8224 None The VSS service is shutting down due to idle timeout.
Information 04.01.2014 01:26:53 VSS 8219 None Ran out of time while expanding file specification \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy11\W indows\softwaredistribution\Download\0dcbdf0cd3181 da68ea1a0cad87fcd81\*.*. This was being done for the WUA subscriber.
Operation:
OnPostSnapshot event
PostSnapshot Event
Context:
Execution Context: Shadow Copy Optimization Writer
Execution Context: Writer
Writer Class Id: {4dc3bdd4-ab48-4d07-adb0-3bee2926fd7f}
Writer Name: Shadow Copy Optimization Writer
Writer Instance ID: {424b377c-ea64-4adf-bc20-fa0eea778a05}
