Page 11 of 21 FirstFirst ... 234567891011121314151617181920 ... LastLast
Results 101 to 110 of 203
Thread: CENTRAFUSE new fully functional carPC software
  1. #101
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by RoyN
    It is really slow on my P4 2ghz, 1gb Ram...REALLY REALLY slow.... unuseable... i might try it in the car, but i'm not sure...
    Hmm... I've got a similar setup like you.. a 2.5ghz p4 (100mhz FSB) and 1 gig of ram... its very fast. I think your system is a bit
  2. #102
    VENDOR - Centrafuse veetid's Avatar
    RoyN: Something must be wrong because this program is very very usuable on my P3 800mhz celeron... That is the slowest machine I have run it on and it works great... I built the whole app on my P4 1.6mhz and it was really fast... Not sure what is going on with your setup...
    David
  3. #103
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Hmm weird... what about changing FM for OBDII app? and embedding it too?
  4. #104
    RoyN: I plan on adding an external apps section, which will embed apps just like the GPS does, including the fullscreen option. It won't take me long to add this, you can expect it soon.
    David
  5. #105
    São Paulo, Brazil
    Thanks!
    Will you have OSK support, and Minimize app support? (To keep an application running minimized then go back to it?)
  6. #106
    RoyN: It will have both minimize and osk, very similiar to the web browser...
    David
  7. #107
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    little slow here also, P4 2.6 Ghz 512 ram
    loading screen last about 4 sec, reminds me of media engine.
    otherwise its really nice.
    dim function is buggy, no way to reset it to original gamma level.
    also getting crash on id3 read
    ************** Exception Text **************
    System.Data.OleDb.OleDbException: Could not find file 'C:\Program Files\fluxmedia\centrafuse\system\main.dat'.
    at System.Data.OleDb.OleDbConnection.ProcessResults(I nt32 hr)
    at System.Data.OleDb.OleDbConnection.InitializeProvid er()
    at System.Data.OleDb.OleDbConnection.Open()
    at centrafuse.id3reader.id3read_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.2032
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    centrafuse
    Assembly Version: 1.0.1799.26149
    Win32 Version: 1.0.1799.26149
    CodeBase: file:///C:/Program%20Files/fluxmedia/centrafuse/centrafuse.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Data
    CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    Microsoft.DirectX.AudioVideoPlayback
    Assembly Version: 1.0.900.0
    Win32 Version: 5.3.0000000.900 built by: DIRECTX
    CodeBase: file:///c:/windows/assembly/gac/microsoft.directx.audiovideoplayback/1.0.900.0__31bf3856ad364e35/microsoft.directx.audiovideoplayback.dll
    Accessibility
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    Microsoft.DirectX.DirectSound
    CodeBase: file:///c:/windows/assembly/gac/microsoft.directx.directsound/1.0.900.0__31bf3856ad364e35/microsoft.directx.directsound.dll
    Freedb
    Assembly Version: 1.0.0.1
    Win32 Version: 1.0.0.1
    CodeBase: file:///C:/Program%20Files/fluxmedia/centrafuse/Freedb.DLL
    Microsoft.DirectX
    CodeBase: file:///c:/windows/assembly/gac/microsoft.directx/1.0.900.0__31bf3856ad364e35/microsoft.directx.dll
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  8. #108
    SWC
    SWC is offline
    Aug 2004
    Baltimore
    Thanks!
    Also as far as speed goes. I have similar issues sometimes its lightning fast, other times it takes 5-6 seconds to switch between screens. I am testing it ona p4 2.8 1 gig of ram.
  9. #109
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I sometimes have problems with speed on my home computer as well. P4 2.8 1gig of ram and XP Pro.
    @veetid, I think you should make another thread for the bugs, other wise this thread will get really big. Just a suggestion.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  10. #110
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    Is it posibel to make other skin to this nice front-end
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
  1. State of Linux CarPC software
    By Change in forum Software & Software Development
    Last Post: 11-16-2004, 02:53 AM
  2. carpc software progress
    By jwrpalmer in forum Software & Software Development
    Last Post: 11-12-2004, 10:36 AM
  3. CarPC software from Xenarc
    By Alric in forum Software & Software Development
    Last Post: 07-16-2004, 02:38 PM
  4. CarPC Software Launcher
    By Confused in forum Software & Software Development
    Last Post: 05-01-2004, 12:10 AM
