Page 4 of 21 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 203
Thread: CENTRAFUSE new fully functional carPC software
  1. #31
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by veetid
    Thats weird... Nothing related to accessing the A drive in the app, unless you set the music path to A or have a playlist with a path to A. This has been run on lots of computers and configs and I haven't heard that one yet.... I will look into it.. Anything notable about your config? Not sure how I can reproduce this one
    It should work fine with NaviVoice Also a great program BTW
    David
    So the A problem has been fixed with the erasing of the config file. I'm gonna guess that it was related because I didn't have that directx thing installed and I didn't reinstall centrafuse.
    BTW: How do I just play albums w/o adding them to the playlist?
  2. #32
    Newbie Talon's Avatar
    Jun 2004
    Charlotte, NC
    Really odd - I'm getting the same A: drive thing. I'll try removing the config file...
    www.carolinacarclubs.com
  3. #33
    VENDOR - Centrafuse veetid's Avatar
    0l33l... Currently it only plays playlists... There is an option in setup that says "Clear Playlist". If you enable this option it will automatically clear the playlist and by default be in id3 mode in the last place you were located... So once that is enabled all you do is select the album you want and click "++", then click load and it will start playling...
    I am planning on also adding a "play now" button to the bottom of the music manager, which will automatically clear the playlist and play the selected album or directory...
    David
  4. #34
    Variable Bitrate HummDinger's Avatar
    Aug 2004
    Milwaukee, WI
    This is an awsome piece of software. It is amazing what is emerging lately as far as front ends go.
    You can still have something if you have nothing
  5. #35
    FLAC alti's Avatar
    NY
    wow, that site is sweet....
    Downloading now.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  6. #36
    Jul 2004
    Berkeley, CA
    David
    Sounds great BTW: How would I find the embedded GPS program? I'll add a centrafuse option to NaviVoice
  7. #37
    Aug 2004
    Milwaukee, WI
    Im making the switch again. I just recently switch from mediacar to frodoplayer, now I think I may be switching again. I like the organization in this program a whole lot more. Accessing the player controls from all menus is a definite plus with me. Plus all the other features (there working yippee) make this a dominant program. Also I haven't noted any problems or errors (yet anyway)....
    KUDOS to you sir or mam? Im definitely one happy boy today....
  8. #38
    0l33l ...You should be able to still just grab the window handle of the app I am embedding. So if a user is, for example, using routis with centrafuse he would still just select the routis option in NaviVoice. I haven't tried it out, but I think it would still work.
    David
  9. #39
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    looks great...
    i just cant seem to get .wma to play
  10. #40
    lawrence... Do you have "Managed DirectX" installed? Does it play other music files?
    David
  1. State of Linux CarPC software
    By Change in forum Software & Software Development
    Last Post: 11-16-2004, 02:53 AM
  2. carpc software progress
    By jwrpalmer in forum Software & Software Development
    Last Post: 11-12-2004, 10:36 AM
  3. CarPC software from Xenarc
    By Alric in forum Software & Software Development
    Last Post: 07-16-2004, 02:38 PM
  4. CarPC Software Launcher
    By Confused in forum Software & Software Development
    Last Post: 05-01-2004, 12:10 AM
