Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: destinator and centrifuse
  1. #11
    Maximum Bitrate knubile's Avatar
    A little more detail please ninja monkey. Or anyone else. What version of D3 Frontend are you using? Which file did you point Centrafuse to and what window name did you give it?
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    @ ninja money have you tried exiting the desintantor and reloading it? Does that work ok?
    @veetie deleting the config file helped with "the can't play file type" error. Thr first time I rqan setup I choose the incorrect folder, I then change it and I think this messed up the config file.
  3. #13
    VENDOR - Centrafuse veetid's Avatar
    bertybasset: If you exit Destinator inside centrafuse, it will not reload it again... This is by design, currently... Basically the first time you launch GPS it runs the specified program and embeds it... It assume you won't ever close it... CENTRAFUSE will automatically close out your specified application when it exits... I am probably going to add a check everytime the button is clicked to make sure the app is loaded and if not attempt to load and embed it again... Originally I planned on being able to remove the top file menu of applications also, which meant you really wouldn't have been able to exit from most apps once embedded, so I didn't need it to re-check...
    Currently if you change your music path in setup you have to go clear out your current playlist and re-load songs in order for the path to be corrected and stop getting the unable to play file... I think you will have to also open up your playlists and change the path also, which I should probably do in the app, but just realized it
    david
  4. #14
    Sep 2003
    Gloucester (UK)
    correct about that unless you have always show on top enabled in setting. I've just noticed that desinator is always loaded behind the top centrafuse windows.
    When always show on top is disabled the program works as expected.
    Looks like a bug a design feature.
  5. #15
    so when "always ontop" is enabled it doesn't embed the application?
    david
  6. #16
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    @ David,
    All my problems on my office PC have miraculously disappeared when I burned the complete directory Dest3.1 to a CD, with the CF install files, everything worked first time :-)
    Only problem is that while we're testing NM's Dest there are still some bugs in it, so occasionally it can act a little wierd, and sometimes it crashes, and so has to be re-loaded. A little reset button hidden in the window where NM-D3 embeds would be nice cause you'd only see it when you needed it.
    EDIT: What I mean by reset is to reset CF back to its state pre-D3 loading.
    My next problem is OT really, I seem to have killed my CarPC's HDD last night to the point where it won't even recognise it in BIOS!!!!! F***ING B***ARD!!! ARRRGGG!!
    Back to the drawing board... :-(
    John
  7. #17
    Sep 2003
    Gloucester (UK)
    it emebed ok the first time you press GPS then centrafuse app sits on top of the GPS windows faking you in to believing it broken but really it's not.
  8. #18
    I will be adding a check in the GPS to make sure the GPS application is loaded and embedded, if not it will re-load...
    Glad it worked out for you
    david
  9. #19
    bertybasset: I will look into the ontop problem.. thanks...
  10. #20
    VENDOR - SpatialMinds millec's Avatar
    Dec 2002
    Mt. Vernon, WA
    Embedding Destinator (unsolved) and Clean return to Centrafuse (solved)
    How do you "embed" Destinator3? Centrafuse will load Destinator3, but runs it separate without any sort of a Centrafuse skin or overlay. When I exit Destinator 3, I can get back to Centrafuse but can no longer load the Destinator if I select GPS again. I guess my question is, how do I embed destinator, and how do I exit destinator to return to Centrafuse w/o unloading destinator.
    My settings:
    GPS Path - c:\DestinatorApps\FrontEnd\Destinator3.exe
    GPS Window Name - Destinator3
    To those who can't Centrafuse to reload after exiting Destinator, check that your GPS Window Name matches the name of the Destinator Window (E.g. Destinator3). Hit ctrl-alt-delete to list the current processes and get the name of the window if you are unsure what it should be called.
