Results 21 to 30 of 33
Thread: destinator and centrifuse
  1. #21
    VENDOR - Centrafuse veetid's Avatar
    If the window name was correct it would embed inside CENTRAFUSE... If you are using the D3 Frontend fron Ninja the GPS window name should be
    D3 Front End / Destinator 3 - [Dest3.1]
    I personally haven't used destinator, but check out this thread.
    GPS window names
    david
  2. #22
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    Quote Originally Posted by veetid
    GPS window names
    And this one: Re-Opening NM Destinator 3
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
  3. #23
    Oct 2004
    Bay Area, CA
    Exclamation
    Well I was having the same problem with Destinator not embedding into centrafuse - but after giving centrafuse the right name it has embedded ok.
    A few questions though:
    When Destinator 3 is embedded into centrafuse, and I try to enter a destination, the list of possibilies is shrunk down so I can't choose any. You can recreate this problem by trying to go and search for a POI. Tell D3 to do a POI, then choose a category. At this point it will list out possibilities, which you cant see because it's been shrunk down.... Help?
    Also, any progress on the refresh mechanism? I notice that when I try to drag the map to view a different direction, it will not refresh. It does move it, because I can press a different button and it will load ok... Help again?
    Other than that, I have to say that this is an AWESOME AWESOME AWESOME frontend!!!!!! PERIOD! Keep the updates coming! -Brett W
  4. #24
    Mar 2004
    Mrbmw99 -> If you click the main title/info bar of the Centrafuse app while in GPS mode the GPS window will resize tot 'almost' full screen. That allows just enough room for the controls of Dest3...
  5. #25
    VENDOR - SpatialMinds millec's Avatar
    Dec 2002
    Mt. Vernon, WA
    Quote Originally Posted by Mrbmw99
    What name did you give it, and could you post a screenshot of destinator embedded? I can't figure out if what I have is working, or not because I don't know what it should look like if it is embedded.
  6. #26
    Dec 2002
    Mt. Vernon, WA
    Quote Originally Posted by C4M
    The only window name that is semi working for me is Destinator3. I am starting to think that the problem is the combination of centrafuse and the latest version of Destinator?
    --Craig
  7. #27
    C4M
    C4M is offline
    Apr 2002
    Sydney, Australia
    Quote Originally Posted by millec
    --Craig
    No. Compare my XML with your XML in your config file - I'm sure you'll find there is a difference. I am using the latest version of NM's Destinator - v1.1.0.314
    Did you read the thread that I referenced above? There is a screenshot in there!
    C!
  8. #28
    Dec 2002
    Mt. Vernon, WA
    C!
    It looks like I have installed an old version of destinator.
    Yes, I read the *post* you referenced above, you did not reference a thread though.
    --Craig
  9. #29
    Dec 2002
    Mt. Vernon, WA
    It works like a charm if you have the right version of destinator.
    --Craig
  10. #30
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    The strings D3 Front End, Destinator3 or any of the others mentioned in this thread will definitely not work because they don't appear in the window title!
    Copy and paste the below and destinator will embed. Yes, even the latest beta.
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
