It works with the D3 frontend, but haven't heard of anything else. Which version of Destinator are you trying to run?
david
Has anybody gotten this to work? I've used the proper window name with now success.
david
I've found when you exit/quit on the monkey front end it doesn't quit the GPS app correctly task manager states it is still running and cantrafuse won't load it again till shutdown and restarted.
Ya. I'm using D3 Frontend. I tried 1.1.2 and 1.1.3.
Is there any logging going on? I don't see a log file. Can it be turned on?
Here's the screenshot of the result of clicking on GPS on the main window.
Before I start to embed Destinator3, I would like to ask if anybody already has developped Dest3.1 skin that matches Centrafuse?
my problem is that it embeds right, but it wont display motion, the map just sits in one spot it wont refresh untill hit a button like the menu button. then it will quickly update and display the menu.
CarPuter ProgressO meterO
[+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
visit me on the web at
http://gozips.uakron.edu/~cmk23/
I haven't finished the logging yet, but it will be in the next version... I will try and get a copy of D3 so I can test... So far I have only used it with Routis, iGuidance, Mappoint, Street Atlas and I didn't experience any of these problems...
Not sure about the embed problems.. There are a few other people that seem to not be having any problems... Try and ask them what they did...
david
Works fine for me!
Destinator 3 For PC! - http://www.map-monkey.co.uk/
