Page 10 of 30 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 300
Thread: Requests..... Please
  1. #91
    Jan 2005
    A small request from me:
    I'd like to see a separate volume setting for videos. Most of my videos/DVDs are at a significant lower volume than my mp3's which most of the time peak at 0 dB. DVD's have a much larger dynamic range. So when I quit a video the sound levelfrom the music player blows my ears off.
    Either an independant volume slider for videos or a compressor plugin that "shrinks" the dynamic range and normalize it to 0 dB.
  2. #92
    New York
    don't know if this has been mentioned yet.
    m2v video support and vob support. there was another thing, but i don't remember at this moment.
  3. #93
    VENDOR - Centrafuse veetid's Avatar
    DaRacerz: CENTRAFUSE can play any video/audio format you have codecs installed for. After you have the codecs installed for whatever video/audio format, just edit "config.xml" in the system folder and add the file extension.
    david
  4. #94
    Dec 2004
    Champaign, IL
    I love this program!!
    I'm just getting into this whole CarPC thing, and checked out Centrafuse but was a bit hesitant due to its beta status. But after trying out several other front-ends, I kept coming back to Centrafuse! This program is awesome! Once external apps are supported it will be everything I wanted! I'll be using this primarily on longer-distance trips with the wife and kids. So now for some feature requests:
    1) Would it be possible on the weather page to have some sort of quick-link to change the ZIP setting on the fly (and update the weather) such as just touching anywhere on the weather page, or perhaps store multiple locations that can be quickly accessed? Sure, I can change the settings page on the fly, but that's tedious.
    2) I don't want the music to auto-play at startup.
    3) Any way to toggle the "Play" button to a "Pause" button to be more intuitive about starting/stopping music? Also, no stop button?
    4) Definitely want External App launching support
    5) Any way to auto-play DVD's like you do for CD's? I'm trying to make the setup as simple as possible for my wife, who just wants it to play DVDs.
    Great work!
    Erik Coleman
    Via EPIA M10000
    Travla C134
    Windows XP Tablet PC Edition
    Xenarc 700TSV
  5. #95
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    doesn't the play button already toggle for pause?
  6. #96
    Dec 2004
    Champaign, IL
    Quote Originally Posted by silencery
    The behavior toggles between play/pause, I'm being nit-picky and would like the icon itself to toggle between the ">" and "||", to assist the non-computer users riding in the van.
  7. #97
    ecoleman: I plan on allowing you to have multiple weather codes and some arrows that let you toggle from screen to screen.... I also plan on making the auto play music on startup an option.... External apps will be in the next version and I also plan on implementing auto play of DVD... So you should expect all the features you are looking for in a future release
    note: I left the stop button off because it seemed useless to me... If you don't want to hear the music click pause. If you want the song to start over, hit previous. Works just like all car stereos... They don't have stop buttons... I also agree with showing the pause icon, but its currently a limitation of my skin, which only has off and down states for each page... So no where to store the pause icon...
    david
  8. #98
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    David, I've noticed, I manually added OGG to the files, and with the codecs installed it plays them fine. But if you run settings again, it doesn't just load the file alter it and save it, it overwrites it, so it removes any custom changes you make in it.
    Might it possible to seperate the file out into a seperate one for audio/video formats, then they can't be accidently overwritten.
    4x4 in a turbo stylee.
  9. #99
    Skraggy_uk: That is a bug... It is suppose to remember and keep any changes you make manually to the file. I will get this fixed..
    david
  10. #100
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Synchronization feature to automatically add music files on a usb flash drive into your music directory
    Or through wifi but I personally prefer USB because I can never get a good wifi signal from my car
    Edit: you know what....this can be done througha simple bat script
    Just link the bat script as an external program in the frontend and then write the bat file to xcopy all files ending in an mp3 extension to a specified music directory
    Too easy
  1. Feature Requests
    By frodobaggins in forum PowerVoice
    Last Post: 02-20-2006, 02:03 AM
  2. Requests / Suggestions
    By netsuo in forum NeoCar Media Center
    Last Post: 01-06-2006, 07:39 AM
  3. D3 Front End: Enhancements/Feature Requests
    By Dominik in forum Map Monkey
    Last Post: 12-28-2004, 02:44 PM
  4. Official requests thread.
    By skippy76 in forum V.O.I.C.E.S
    Last Post: 06-03-2004, 02:56 AM
  5. Replies: 15
    Last Post: 03-07-2004, 10:23 AM
