Page 26 of 30 FirstFirst ... 161718192021222324252627282930 LastLast
Results 251 to 260 of 300
Thread: Requests..... Please
  1. #251
    VENDOR - Centrafuse veetid's Avatar
    Frankino: I think I actually only added that functionality in the DVD section... I have decided to just add a Play DVD in the video section instead of having two seperate sections, so it will work like I described in the next release. For now you just get that functionality in the DVD.
    david
  2. #252
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    great, I hope aspect ratio correction is implemented too
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  3. #253
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    veetid: any ideas on a release date yet!!! Sitting waiting patiently
  4. #254
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    I don't know if this has been disscussed before, but voice commands only work for me when I mute the radio first, so if it could auto-mute or auto-pause when the system is "listening", that would be an awesome feature.
  5. #255
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    i think the main problem with that is that most people will end up leaving the voice command on most of the time, so unless you want to have the radio off the majority of the drive, it wont work well. maybe try and rig a mic up near the driver? a sensitive mic in the headrest maybe?
    Your everyday carpc geek and tech guru at your service. *bow*
  6. #256
    Nov 2004
    L.A.
    If I leave it on all the time, I find CF randomly switches screens because it thought it heard a command (and a more sensitive mic would only make that worse).
    I mapped a button on my remote control to voice command toggle, so if I want to get to a screen that I don't have a button for on the remote, I press the voice command button, say "computer, ...", then press the voice command button again to turn it off. This works well, but as I said, I also have to mute my head-unit first.
    I suppose I could just use Girder to make the voice command button both pause and enable voice, but then there is a chance they could get "out-of-sync". It would be nice if you could just enable an option to auto-pause with voice command (or possibly just set the volume to 10% and then back to whatever volume you were previously at when you dissable voice).
  7. #257
    Nov 2004
    L.A.
    If I leave voice enabled all the time, I find CF will randomly switch screens because it thinks it heard a command. A more sensitive mic would only make that worse.
    I have voice command mapped to a button on my remote, so when I want to goto a screen that I don't have a button for on my remote, I press the voice command button, say "computer, ...", then press the button again to dissable voice. This works well, but I also have to mute the headunit for it to work reliably.
    I suppose I could use Girder to map the same button to first pause, then enable voice, but then there is a chance they could get "out-of-sync". It would be better if CF had an option to pause with voice enabled (or just lower the volume to 10% and then restore previous volume level once voice was dissabled).
  8. #258
    Nov 2004
    L.A.
    Oh, another problem (bug) in CF is that when I press voice command on my remote, the icon on the bottom bar in CF does not instantly change state. It will sometime happen within a second, but other times it will not change until it switches songs or recieves a voice command to goto a different screen.
  9. #259
    Jan 2005
    Warren, Ohio, USA
    that is more than likely a problem due to the original way the UI was developed. david said he has redone it and it will be available in the next released version. this will also speed up CF dramatically.
  10. #260
    Jan 2005
    Warren, Ohio, USA
    just wanted to point out that i did try the volume thing with dvd and it worked as far as coming out of dvd mode and reverting to the previous volume, but when going back to dvd, it stays at the mp3 volume. in my case, mp3 volume was 30%, went to dvd, set to 70%, went back to mp3, it went to 30%, went to dvd, still 30%.
  1. Feature Requests
    By frodobaggins in forum PowerVoice
    Last Post: 02-20-2006, 03:03 AM
  2. Requests / Suggestions
    By netsuo in forum NeoCar Media Center
    Last Post: 01-06-2006, 08:39 AM
  3. D3 Front End: Enhancements/Feature Requests
    By Dominik in forum Map Monkey
    Last Post: 12-28-2004, 03:44 PM
  4. Official requests thread.
    By skippy76 in forum V.O.I.C.E.S
    Last Post: 06-03-2004, 03:56 AM
  5. Replies: 15
    Last Post: 03-07-2004, 11:23 AM
