Page 30 of 30 FirstFirst ... 2021222324252627282930
Results 291 to 300 of 300
Thread: Requests..... Please
  1. #291
    Jun 2005
    Washington
    i would really like an aspect ratio button in video playback or maybe for it to do it automaticly like the dvd... thanks
  2. #292
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    Quote Originally Posted by compnut21
    it is already working if you use ffdshow decoder and automatic aspect ratio correction
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  3. #293
    New York
    Utilities Section: Most of the Launcher programs in other FE handle .exe but not .jars (Java Packages), any chance of getting that supported directly?
    Mark
    Website: http://www.greenpowerenthusiast.com/
    Car'Puter Project
    - Xenarc 700TSV
    - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
    - 1x 256MB Corsair XMMS DDR400
    - M2-ATX
    - Belkin 802.11G W-Nic
    - Garmin 15H GPS
    - WinXP SP2 (NLited)
  4. #294
    VENDOR - Centrafuse veetid's Avatar
    DaRacerz: In my external apps section in 1.3 you should have no problems launching a jar file, as long as you can double click them in windows and have them run it will work...
    david
  5. #295
    Mar 2005
    Covina, CA
    a position bar so you can quickly skip through movies and mp3s to certain parts
  6. #296
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Yeah... a slide bar is much better than REW/FF buttons.
  7. #297
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    i know i put out ths request already, but it was in another thread so i am not sure you saw it.
    winamp plugin support: fairly simple. and the benefits of such should be simple to see. heres a breakdown:
    input: allow playback of odd formats that are otherwise not possible to playback through thw wmp/dx system (such as aac or mp3pro or really odd formats such as SPC which is a super nintendo sound format)
    vis': already inplemented in 1.3 so im sure you see that benefit already
    dsp: allow each user to customize the sound for their exact system to a "sweet spot"
    and while im not big on source code and whatnot, winamp has a really good sdk on their site if it will help any.
    Your everyday carpc geek and tech guru at your service. *bow*
  8. #298
    I am currently building an SDK for CF that will allow many things including implementation of custom DSP effects... I do plan on adding winamp visualization support directly in CF... You can already play aac files in CF very easily... Simply install an aac codec and it will work...
    note: you also have to add aac as a supported extension in your config.xml
    david
  9. #299
    Nov 2004
    L.A.
    Currently you cannot run apps with command-line parameters. Can you add this (either as a seperate <parameters></parameters> key or just allow the command to include it like "explorer.exe c:\") in the external.xml.
  10. #300
    Nov 2004
    Italy
    Quote Originally Posted by RPM_VR4
    autoit for now solves this problem
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  1. Feature Requests
    By frodobaggins in forum PowerVoice
    Last Post: 02-20-2006, 02:03 AM
  2. Requests / Suggestions
    By netsuo in forum NeoCar Media Center
    Last Post: 01-06-2006, 07:39 AM
  3. D3 Front End: Enhancements/Feature Requests
    By Dominik in forum Map Monkey
    Last Post: 12-28-2004, 02:44 PM
  4. Official requests thread.
    By skippy76 in forum V.O.I.C.E.S
    Last Post: 06-03-2004, 02:56 AM
  5. Replies: 15
    Last Post: 03-07-2004, 10:23 AM
