ok, i was testing this software out, but for some reason when i click an mp3 to play, it says unable to Play along the top?
any ideas, do i need a specific player installed?
Printable View
You need managed directx. :search:
try deleting the config.xml file this will cuase setup to be re-run and it will fix the problem., did for me.
Had your proble, solved it with 0l33l solution...
