The connection status in the top right only displays the internet status. PhoneControl only connects to your phone for use in dialing, hanging up, retrieving phonebook, etc..., nothing to do with internet. You need to setup a Dial Up Networking connection for your phone and set it up to dial whatever you dial to establish a data connection with your provider.. I use AT&T which is *99# I think... Then go to tools/internet options/connections in IE and setup the new conenction as your default internet connection... CENTRAFUSE is then able to control your default internet connection.. It will say disconnected, but once you click it, it will dial your default internet connection and change the status to connected... You can also click it again and it will hang up your default internet connecetion... You just click it and have it dial when you need to use it and hangup when you are done...
It will also say connected when it sees any type of internet connectivity... so if you have wireless hooked up and it gets a signal, it will change and display connected... If run on a desktop with LAN, it will always say connected and so forth...
david
LinkBack URL
About LinkBacks
