Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Can your software use an offline copy CDDB or FreeDB when ripping CDs?
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    Question Can your software use an offline copy CDDB or FreeDB when ripping CDs?
    Can your software use an offline copy of CDDB or FreeDB when ripping CDs? If it can where do I store the database?
    VENDOR - Centrafuse veetid's Avatar
    It already does essentially... When you are connected to the internet and you rip or insert a cd, it will find the CDDB entry and store it locally... Then any other time you put that cd in, it first queries the local DB In the system folder, "main.dat", and retrieves your info. This is just an access file with a FreeDB database in it. You can get your carputer on the internet and insert all your cd's one time, therefore having all there data stored locally. You can also try to download the entire freedb database and import it into my access file. Not exactly sure what format they use, but I store all the data you retrieve from them so it should be compatible.... Its a HUGE file to download, but should work...
    david
    Sep 2003
    Gloucester (UK)
    importing into your database sounds like a good idea. The DB is less than 500Mb so it's that small.
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    if you figure out how that works, let me know!
    CarPC install is starting to come along again...
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Thats a good idea, I have plenty of space on my HD so i'm going to play with that later tonite.
    肚子笑痛了
    S60 Install
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    I tried doing this for CDex...but it didn't work. Never figured out why (though I tried), so I just deleted it. Not a bad idea, though. I think I'll try to figure it out again sometime in the near future.
    Mac Car Moderator kandyman676's Avatar
    Maryland
    where would you get a copy of the DB? *looks confused*
    "If it works this good why F with it?" -KMFDM "Intro"
    Strive for ethical wardriving: http://faq.wardrive.net/
    My CarCPUs: v1 - 2000 | v2 - 2004
    Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
    Low Bitrate omar's Avatar
    Dec 2004
    San Diego
    You can download the database here:
    freedb.org
    http://www.freedb.org/modules.php?na...ticle&artid=12
    TX5
    TX5 is offline
    Sydney
    have a look at this thread
    Cd Ripping and CDDB
    AMD XP 2000+ 512Mb Ram MB:A-7VM400AM-RZ
    Zenarc 700TSV Netgear USB WiFi GPS Opus 150
    Running Win XP, FP, MM
    someone try and import the data into my "main.dat" file inside your CENTRAFUSE system folder. Just open with Access. Let me know if I need to modify the DB format to simplify the import process...
    I am pretty sure the file is 500MB compressed, but a lot larger when uncompressed into text... It would probably shrink back up once imported into the DB. If anyone gets it all imported please post a link to your CENTRAFUSE main.dat file so I can include this with my app...
    david
  1. CoPilot 2002 software CD's
    By saabmp3 in forum GPS
    Last Post: 08-28-2004, 02:45 AM
  2. Cd Ripping and CDDB
    By OriginalNick2 in forum Media Engine
    Last Post: 07-09-2004, 06:42 AM
  3. Ripping CD's
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 02-22-2004, 01:37 PM
  4. need help ripping cds
    By e36mp3 in forum General Hardware Discussion
    Last Post: 11-08-2002, 09:19 AM
