Results 1 to 6 of 6
Thread: External Applications
    Oct 2004
    Bay Area, CA
    Hi! I was curious enough to want to ask.. How will external applications be handled? I would like to be able to launch and external app the exact same way as I can my GPS, with the button located on the side. That way it's easy to get to. I want to have a program embedded into the system that allows me to get rid of some wiring and switches in the truck (this was one of my goals). I would like to simply tap a button on the left bar (where the GPS button is), and have it load my app. I tested this out, but it made centrafuse run it as the GPS software. It works great! Any idea how this will be taken care of in the later versions?
    It's getting late, so excuse me if I worded this really funky..
    VENDOR - Centrafuse veetid's Avatar
    Already working on it... You will be allowed to specify up to 6 extra external applications, in the same way as the GPS. There will be an external app section for launching all of them. Also All the actions for the buttons on the left will be programable. So you you change the text and action to do whatever you want.... Should work just like you need it to
    david
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by veetid
    david
    You will have command line params right?
    I saw you mention that earlier, but wasn't sure what you meant... Explain more in detail... I will definetly add something to help you out... You need command line parameters for centrafuse.exe to make it auto do what? Is this even on the right track as to what you need..
    david
    Jul 2004
    Berkeley, CA
    david
    No, but for all apps. Like I would like to set navivoice as the GPS app with a command like parameter to open up the real navigation program so that centrafuse will catch it. That way we would have two programs open.
    Command like parameters are things you type into a command prompt (navivoice.exe /startgps).
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    do not forget to embed Dscaler with some control buttons (maybe channel, volume, teletext and input selection)
    by the way, awesome program this centrafuse, really astonishing
    I't been a while since I've seen a piece of WORKING software like this
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. laptop external hard drive question
    By Kato in forum Power Supplies
    Last Post: 06-15-2004, 02:45 PM
  3. Replies: 0
    Last Post: 05-24-2004, 07:48 AM
  4. External applications screen screenshot
    By CarComp in forum ME Archive
    Last Post: 06-06-2003, 02:45 PM
  5. Replies: 0
    Last Post: 06-03-2003, 12:58 PM
