Results 1 to 10 of 18
Thread: push buttons
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    push buttons
    Hey everyone,
    I am playing with the idea of having actual buttons to select the different apps/screens (i.e. radio, gps, mp3) to give my install a more 'factory' look.
    something along the lines of this:
    So I was wondering what would be the best way to do this with centrafuse.
    Thanks in advance,
    Scott
    Nov 2004
    NY tri-state
    Well... you could get some phidgets and have a VB daemon running that would capture each button press... then "tell" CentraFuse to change the screen to the matching button or something. I don't know if it's possible to talk to CF like that, but the rest of it should be fairly straight-forward and relaitvely cheap to accomplish.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    there has been a fair bit of discussion on adding buttons, interfacing with oem stereo controls etc.
    Possible solutions are direct serial interface (or using a serial button control board to add more buttons),
    Hacked game pad
    Joystick port (anologue - possible volume, high speed scanning implications)
    Also look up girder and the girder HID (human interface plugin) which can be used to get signals from joysticks, gamepads etc.
    As for direct with centrafuse maybe you can make a plugin to bypass girder.
    There is lots of info ont he forum if you do a thorough search on soem of the things i mentioned (look in input devices)
    Andy
    VENDOR - Centrafuse veetid's Avatar
    CENTRFAUSE supports configurable hotkey's for just about every action in the application. You would just need to make your push buttons send a key sequence and CENTRAFUSE will do the rest.
    david
    Nov 2004
    NY tri-state
    Quote Originally Posted by veetid
    david
    Doesn't look like a big deal then... maybe build a minimal skin with nothing on screen (well, maybe an exit button or something ) and bread-board a few of these puppies in there...
    http://phidgets.com/index.php?module...iew&CID=6&KID=
    A joystick/multi-turn and a few pressure sensors going into the USB port, then some quick VB work to read what's being pressed, and pass the commands to CentraFuse via SENDKEYS from VB, I guess... sounds so cool it makes me even wanna get involved with it.
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by viguera
    This is really cool, centrafuse never stops impressing me!
    If you want to get involved with this it'd be awesome! I don't know anything about code, so that would be the hitch in this for me.
    Would the easiest way be to hack a 4 or 6 button game pad and then map it to hotkeys in centrafuse via vb? (does this make sense to anyone but me :-D)
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by scott_fx
    maybe something like this:
    or
    http://www.ultimarc.com/ipac1.html
    Dec 2004
    Los Angeles Ca
    This is cool, it can be wired to your keyboard input and it sounds like it can just replicate key strokes.... so this would be pretty easy to do with out any programing
    Nov 2004
    NY tri-state
    Well to tell the truth I have NO use for this at all... my console is pretty packed with buttons and I'm going another route right now with the screen. But it should be really easy for you to pick this up... and if you want I can help you out with the VB code for the phidgets. The stuff is dirt cheap, so if you want to try and get a couple and mess with them as a test, I'll help you out with the code. If I get bored enough over the next week or so, maybe I'll do something myself and let you know what the code looks like.
    Well hacking a joystick/gamepad is easy... and there are people that have done it already if you search around.
    Dec 2004
    Los Angeles Ca
    or would it be better to just hack something like this:
  1. How-To: Relocating Screen Buttons
    By Altimat in forum Fabrication
    Last Post: 11-07-2007, 04:48 PM
  2. Where to get black Lilliput buttons
    By Quattro in forum LCD/Display
    Last Post: 09-14-2004, 08:49 PM
  3. Where To Buy Buttons, Switches, Lights?
    By eCarô in forum General Hardware Discussion
    Last Post: 02-22-2004, 03:25 PM
  4. push buttons for custom installations
    By sirope in forum Input Devices
    Last Post: 09-15-2003, 03:45 PM
  5. Illuminated buttons for custom console
    By mccleanp in forum General Hardware Discussion
    Last Post: 01-18-2002, 10:37 PM
