cheers!
I was editing my post when you were answering to it
I see the problem, I hope Radiator guy can help you solving this issue![]()
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
cheers!
I didn't see a bug thread so I'm assuming this is where they go?
I have my mp3's arranged like so:
h:\music
h:\music\ CCR
h:\music\CCR\album 1
h:\music\Sheryl Crow
h:\music\Sheryl Crow\album
When I go into music manager and select Directories it goes to h:\music. The path i have set in settings.
Then if I select something like h:\music\barenaked ladies\Born on a Pirate Ship and hit "Play Now". It plays every song in that directory. Perfect! But when i'm done listening to that I can't get back to h:\music unless I completely shut down CF and restart it, then it'll go back to h:\music.
Is there anyway that I can get back to h:\music with shutting it down?
TimmyM: Yes you should be able to easily get back to the main directory.. On the bottom of the listview there are back and forward arrows... Once you re-load the music manager you just have to hit the back arrow and it will go back... If for some reason the back arrow doesn't work try clicking another mode from the top, like playlist, and then clicking back on directories.. Let me know if it doesn't work, It works fine for me...
david
Crap! why did I know it was going to be something simple like that! I didn't even see that button, I did try going to other mode's and back which doesn't work. But the button does work just fine! Thanks.
Correct me if im wrong, but if i search for lets say "Mario" with the On Screen Keyboard, shouldnt it show me results with anything that has Mario in it? This should include things like "Mario feat. T.I." as well right? It doesnt seem to work that way, can anybody confirm this? thanks again... and great work on CF btw!![]()
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Chita79: Yes it should display anything with the search term used... If you click search while you are in Directories mode, it searches based on the actual filename... Otherwise in all other modes search uses the database of ID3 song titles for its search, so you can get different results depending on which mode you are in....
david
Don't know if this is a problem with Centrafuse or with NM D3 Front End. But when I have D3 embedded within Centrafuse 1.1, it will work fine. I then go and close Centrafuse and I have left over remnants of my map, I did a CTRL+ALT+DEL to see what program was still running, and it shows the Destinator 3 Frontend, is still running. I then go to End Task on this, and then It still will not go away.
When I press the Exit button under Centrafuse, it exits me to Windows. Don't know if this setting makes a difference or not, but thought it might help.
I am sure there are plenty of others using these 2 programs together, between the 2 of them they are awesome. Wey to go Ninja Monkey and David.
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
great, thanks for info!![]()
Only a question, when I add to playlist using artist/genere/album mode, is there a way to sort the songs by name in the list? I mean, the songs are listed in "artist - title" order, sorted by the title; is there a way to sort them in the original order? maybe reading the "track number" id3tag or by name, I think most users keeps the song named something like "01 - Behind The Music.mp3", "02 - Sorry, Mom And Dad.mp3" and so on
To be brief, I like the tag-oriented browsing but I'd also like to sort them in the original cd order
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
