Page 8 of 9 FirstFirst 123456789 LastLast
Results 71 to 80 of 90
Thread: New Release CENTRAFUSE 1.1
  1. #71
    VENDOR - Centrafuse veetid's Avatar
    Cris: Not sure on your volume problem... It's worked fine on all the machines I have run it on. The music manager is pretty simple... You can hit "Play Now" at any time to play the current selection whether it be an ablum, genre, artist, etc... Once you enter the music manager you can add music to the current playing playlist using the + and ++ and hit "load" without interupting the playback. The new songs will be added to the end of the playlist. Otherwise you can clear the playlist and build a new one. Hitting the + key, when a file is selected, adds that one file. If its a folder it adds everything one level deep to the playlist. The ++ adds everything underneath the current selection to the playlist. There is also an option in setup to auto clear the playlist on load of the music manager, if you want to.
    david
  2. #72
    Tainted Love Cris's Avatar
    Romania
    Yeah, I guess it's a matter of getting used to...doesn't bother me that much,
    cause I put all my music in there.
    Volume problem: as I said, this happens on two different computers...If I leave the volume alone, it works great, if I mess with it, it starts to toggle...I can't be the only one here that encountered this...or can I...
  3. #73
    Constant Bitrate asci01's Avatar
    Jun 2004
    Florida
    Quote Originally Posted by veetid
    skydiver: Its kind of a pain... not sure where those values are stored, but didn't look into it much because I plan on implementing real visualizations in a future version. The only way I know to get back to the settings is to copy the geiss.scr file to c:\windows. Then right click destop, properties, screen saver, select geiss from the screen saver drop down, then click settings. This will allow you to get back to the settings screen...
    david
    This is the program I've been waiting for. Outstanding work !
    Btw to change the config, without doing all that, just right click on the file name in windows explorer and click "Configure". You can also click Test to test the new settings.
  4. #74
    Apr 2003
    On the future camera support you are planning on, will it be just loading our own program or will you offer the camera program?
    Because, I plan on using a four camera capture setup in my system.
    All capture cards offer their own program that have for e.g. a four-way split screen for a four-camera capture card.
  5. #75
    Jan 2004
    NYC
    camsgs3: I am not sure why it won't embed. I have never installed it, but I might download this weekend and try and figure it out. Should be able to just type in the title that is displayed by Dragon BTV in the Radio Window Name and it should work.
    david
    well it looks like its a problem on dragons end, the correct windows name is "form1", it embedds but you cant resize the app so it looks like this:
    also what are the *** by the song name and time - even the time is scrolling - the song scrolls to but it has the ***** next to it, is this a bug or something, i also get this by the volume too and that scrolls
  6. #76
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Just for my information. Did any1 actually sucseeded running Destinator3 (1.1.3b3) embedded in CF 1.1?
  7. #77
    Low Bitrate microbionic's Avatar
    Aug 2004
    medina,ohio
    Quote Originally Posted by mpattonm
    it worked well for me.
    CarPuter ProgressO meterO
    [+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
    visit me on the web at
    http://gozips.uakron.edu/~cmk23/
  8. #78
    May 2003
    Czech rep.
    *****. Then its something wrong with my setup. I can not get it working.
  9. #79
    camsgs3: The *** shows up when something is too big to fit inside its space... All my labels will scroll if the text put in them is too long... they scroll with "text *** text"... It looks like the width in the screenshot isn't 800 or 848, did you make a smaller skin? It is normal for the song to scroll, but the volume and time should fit within their space and not start scrolling...
    david
  10. #80
    Jan 2004
    NYC
    ohh ok, Yea the screen shot is from my desktop PC, 1600x1200 - so that explains it, im going to put 1.1 in my car now
  1. Alpha Release: XMPC-CAR for XM
    By gork in forum Software & Software Development
    Last Post: 01-11-2006, 01:19 PM
  2. About time for a MediaEngine release.
    By CarComp in forum Media Engine
    Last Post: 03-17-2005, 02:25 PM
  3. Centrafuse and Vob files
    By chuckster in forum Centrafuse
    Last Post: 01-17-2005, 04:26 PM
  4. D3 embedded in Centrafuse : no OSK
    By superbowl in forum Map Monkey
    Last Post: 01-02-2005, 09:12 AM
