Page 1 of 9 123456789 LastLast
Results 1 to 10 of 90
Thread: New Release CENTRAFUSE 1.1
    VENDOR - Centrafuse veetid's Avatar
    Here is CENTRAFUSE 1.1. Any translation files you may have created will need to be updated to the new version, your old ones will not work. I added a few new fields and changed the meaning of some of them.
    Visit http://www.fluxmedia.net for the CENTRAFUSE 1.1 download and updated screenshots!
    CENTRAFUSE
    Change Log (1.0 – 1.1)
    The new version is 4x faster and uses almost ˝ the memory. There is a new option in setup for Enhanced Graphics which makes the modes transition smoother, but at the cost of your processor. The integrated character LCD support is for the HD4478 parallel controls and can be configured via “lcd.xml” in the system folder. The new music manager has a “Play Now” button to help make it less playlist oriented. You can click “Play Now” at any point in time. If you are browsing Genres, highlight Rock, and hit “Play Now”, it will play all your music in the Rock Genre. This allows you to simply go into Albums, browse, and just hit “Play Now. Radio can now be configured to launch an external application, with full line-in muting control (make sure your line-in is un-muted), instead of using the integrated radiator. (use to launch XM program or any other radio program you want to use)
    New Features in 1.1
    1. speed/optimization improvements and improved memory management
    2. music/video managers run full screen, a lot more touch screen friendly
    3. integrated output to parallel LCD’s
    4. radio can either use integrated radiator or embed an external app
    5. play now button added to music manager
    6. browse by album art added to music manager
    7. previous button replays the current song, if past a few seconds
    8. removed filter functionality and added a true search to both music/video managers
    9. re-worked the listview paging and now display the current page you are on
    10. automatically moves to next song if it can’t play the current one
    11. when no cddb and ripping a cd, tracks now labeled with leading 0’s
    12. cdripper adds id3 information to files, when available
    13. cdripper appends ripped songs to your music database, no need to re-run id3reader
    14. improved weather screen, easier to read
    15. changed the wording in setup, easier to understand
    16. added “pause video” option, when disabled it allows you to listen to video audio throughout the application when you hit back from video mode. The video is automatically paused once you click on any type of music or radio station. (note: if you using external radio program instead of integrated radiator, video will always be paused when you enter this mode. This is because I don’t have control over when to pause the video once you start using your external radio app again, but video audio will still work in all other modes)
    17. added a confirmation box to the clear playlist button in music manager
    18. random button now toggles between random and repeat
    19. added a hide cursor option in setup that hides the cursor throughout the entire application
    20. when “clear playlist” is disabled songs can be added to the end of the current playlist and when you click “Load” it will not interrupt the current playing song, but simply add the new songs to the end of the list.
    Fixed Bugs in 1.1
    1. loading music manager doesn’t un-pause music
    2. back button remembers old selection in categories mode
    3. enabling/disabling voice doesn’t cause images to display wrong
    4. file copier asks for destination folder
    5. hitting remove in music manager when nothing is selected doesn’t cause error
    6. virtual keyboard responds to keyboard enter command
    7. mute button in dvd/video doesn’t display wrong
    8. centrafuse won’t crash if the database file is missing
    9. when “clear playlist” disabled, current playing song is selected in music manager
    10. filenames with single quotes don’t cause problems
    Features planned for future releases
    1. integrated GPS, using Destinator 3
    2. integrated OBD II support
    3. external applications page (options to pause music and/or mute line-in on exit)
    4. adjustable aspect ratios in video mode
    5. single click option for listviews
    6. search feature within the current playing playlist
    7. more options in the mixer
    8. allow main left nav actions to be configurable
    9. TV/Camera support
    10. XM support
    11. skin editor
    12. file sync with PC
    13. integrated visualizations
    14. auto dim at specified time (day/night)
    15. option to disable dvd, video, visualization, and web while driving (using OBD or serial relay port)
    Variable Bitrate egeekial's Avatar
    May 2004
    Wow, looks great! I'll have to download it and try it out this weekend.
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    Nice!!!
    Dec 2004
    Staten Island, NY
    I'm running it allready. This is by far the best software i've seen! Thanks a Million
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    if you released this an hour ago i would have installed it. i just reformatted my carputer.... and reinstalled mediacar. now it looks like i have something to do tomorrow in the middle of the night...that is unless i get drunk. thank you. i can't wait to try it out.
    rebuilding carpc... kinda..
    Variable Bitrate ryuandwings's Avatar
    Nov 2003
    TN
    GREAT!!! This will give me something to do during work tomorrow.... I mean after work.
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    GPS is a must, good to see that you are working on it for a future update:
    "Features planned for future releases
    1. integrated GPS, using Destinator 3"
    I would also suggest (if it has not been implemented yet) to integrate an interlock for video and vis using the serial input relay circuit described in Rando's thread on the subject.
    "Protecting Privacy and Free Speech Online"
    http://www.eff.org/
    SuperMike:
    "Features planned for future releases"
    This option will be able to integrate with the post you are talking about...
    david
    May 2004
    AZ
    Ahh, thanks, missed that. It is cool that you are integrating that feature.
    http://www.eff.org/
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Sweet! But unfortunately you broke the weather screen.
  1. Alpha Release: XMPC-CAR for XM
    By gork in forum Software & Software Development
    Last Post: 01-11-2006, 01:19 PM
  2. About time for a MediaEngine release.
    By CarComp in forum Media Engine
    Last Post: 03-17-2005, 02:25 PM
  3. Centrafuse and Vob files
    By chuckster in forum Centrafuse
    Last Post: 01-17-2005, 04:26 PM
  4. D3 embedded in Centrafuse : no OSK
    By superbowl in forum Map Monkey
    Last Post: 01-02-2005, 09:12 AM
