Results 1 to 10 of 12
Thread: Folder.jpg
    Constant Bitrate Prindle19's Avatar
    Dec 2004
    Jersey/Virginia Tech
    Absolutely love the Album Art Addition!
    I tried setting your software for *.jpg, but that didnt work.
    Instead of going in and manually renaming the "googoodolls.jpg" to folder.jpg
    is there anyway to automate this process?
    Any way to modify the dos "rename *.jpg folder.jpg" to recurse directories?
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    Code:
    for /r %a in (*.jpg) do ren "%a" album.jpg
    •Micke
    VENDOR - Centrafuse
    raygun's Avatar
    Dec 2004
    Atlanta
    mad dos skillz
    WOW, you have mad dos skillz bro!
    Jul 2004
    VaBch VA
    0|d 5ck3wL
    ... well that and some luck w/ the search function
    •Micke
    Dec 2004
    you the man, worked like a charm!
    David, maybe implement this simple code into your program>
    Mar 2004
    what does all this mean? is there a way of getting Centrafuse to handle albulm art like media engine does and just scroll through all the JPGs in the album directory?
    cheers
    Jamie
    VENDOR - Centrafuse veetid's Avatar
    live2themaxuk: This is just a command you can run that will change all your images to one name. Currently CENTRAFUSE only loads one image, the one you specify in setup...
    david
    Mar 2004
    OK CHeers
    is it an option you would consider implementing as that would be ACE!!
    J
    Constant Bitrate techeros's Avatar
    Mississippi
    how could I use this for keeping the original file name and changing the file extension?
    IE: original name.mp3 --> convert to original filename.aac
    03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
    Carputer Planning |---------*|
    Overall Implementation |---------*-|
    (Stereo complete)
    Computer installed and working
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    Quote Originally Posted by techeros View Post
    You can't. aac and mp3 are two completely different formats of audio files. The above command substitutes different file NAMES for one specific file FORMAT. You can't just substitute formats on the fly.
