im having the same problem.....![]()
I've got the lastest destinator beta from monkey ninja installed and embedded and it doesn't close down correctly when you exit CF. The apps closes but task manager is still listing the apps as running and a manual end task is needed else when you reload CF destinator fails to load.
Hope that makes sense.
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
is it only when embedding Ninja monkey's Destinator? Does it exit and close fine otherwise?
david
yes only when embedded. If you don't use the exit from with destinator if will not work correctly.
When exiting CF it needs to send an exit command to destinator then close.
I send a standard Process close command to all the loaded applications on exit. It appears that when I try and send the close command to Ninja's Destinator three it is locking up my application and not closing either program... One of his older versions accepted the Close command fine, not sure what has changed in the newer one... I will look into trying to kill the process's instead of cleanly closing them, but shouldn't have too..
david
you could also do with a check to make sure the processes are running when you click GPS becuase some times it doesn't load the GPS software.
This looks more like a destinator bug than a centrafuse one.
Do you guys have "Reconnect GPS on power resume" enabled? If you do can you try it with it disabled? It might be a problem with the frontend catching and passing on window messages
Destinator 3 For PC! - http://www.map-monkey.co.uk/
My fault!
Hotfix #3 will fix this
Don't worry mate, mistakes happen. We all still think your a super star.
FYI Hotfix 3 is out !!
