Yeah using touchscreen, how do you adjust right click settings? I was just starting to figure out how to do everything without a right click too. . .
Are you using a touch screen ? Check your right click settings.
[H]4 Life
I'm a lesbian too.
I am for hire!
Epia M10000, 512 RAM, 160 GB HDD, Xenarc TSV
same setup plus SP1
No volume control at all from within CF
Me also volume problem. The +/- buttons (mainscreen etc...) do not work at all but the mixer panel works!
The +/- buttons do flash when pushed but no volume change.
Having the same exact problem here. Erratic volume behavior; but even if I exit centrafuse it will do this. Any fix for this?
Our you using a touchscreen? If so is the "click on touch" option selected in your touchscreen setup?
david
i am using TS - will chesk it later - windows set to double click icons though if that helps...
OriginalNick2: Icon double click might cause a problem also...
david
you cant right click if you enable single click on icons....
OriginalNick2: If you disable it does it fix the problem though? So I can know if it was causing the problem....
Also... There is no reason for right click in CENTRAFUSE and my goal is to have CENTRAFUSE the only app you run in your car.... Once my external Apps support is included, no reason to go back to the desktop. My main goal is to have it run an XPe anyway...
david
