Results 11 to 20 of 21
Thread: What are you doing for XM??
  1. #11
    Nov 2004
    Northern VA
    Touch XM works with the XM direct? I've tried it, but I can't get any sound. I can see/change channels fine, but no sound..
  2. #12
    Constant Bitrate Prindle19's Avatar
    Dec 2004
    Jersey/Virginia Tech
    If you initiate your XM with TouchXM, you may need to manually unmute your line-in
  3. #13
    Nov 2004
    Northern VA
    Quote Originally Posted by Prindle19
    Tried that - didn't work = (
    Everything works fine with Frodo, but I can't get touchXM to work = /
  4. #14
    Nov 2004
    Northern VA
    Big PITA, so if anyone could tell me how to add a second com port to my pc when i know there is a header right on the mainboard for it, id be very thankful.
    There should be an option to enable the port in your BIOS.
  5. #15
    Raw Wave tj!2k4's Avatar
    Oct 2004
    I'm currently trying to work with embedding TouchXM
    once I shut down the computer, the fact that the power is dropped to the usb/serial interface on that when the computer resumes
    Actually, now that I re-read what you originally wrote.. I have the same problem ONLY when I hibernate the carputer [edit: and this is with an XMPCR]. If I do a full restart and let the hardware reinitialize, everything is fine. So I've resigned myself to shutdown/restart instead of hibernating. Ok, so it takes a couple of seconds longer to boot, but it gives me a few extra seconds to warm up the car in the winter.. =|
  6. #16
    Oct 2004
    TouchXM is right on for um, well, touch screens.......but frodos is miles ahead as far as coolness.
    i gotta ditch my time trax, and somehow figuer out how to connect to the COM2 header on my MII1000 board...any idea how that would be accomplished?
    Edit: The motherboard should have come with a cable to connect to the 2nd serial port header on the motherboard..
    Here is the header, this is from the MII-Series manual.. I can't quite figure out how to display the attachment in the post [Edit: nevermind, it displays on its own.. do'oh!], so here is the link
  7. #17
    Dec 2004
    AH HA! i knew the port was there, but nope, no cable! those sons of @#E@@
    I beleive the problem is a usb hibernation woe, like the ninety bajillion already documented usb hibernation woes.
    This is why im thinking a direct serial method should work better
  8. #18
    Jan 2003
    Ruston, LA
    Quote Originally Posted by eleventh
    It needs the magic bytes. There are some programs that will send the
    bytes and then launch TouchXM.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #19
    Oct 2004
    Quote Originally Posted by frodobaggins
    I imagine that the FP-XM module will take care of this for us? =)
  10. #20
    Oct 2004
    Here's what you'd be looking for http://www.buy.com/retail/product_ju...mp&dcaid=17379
