When I am on the weather screen and tab to another app and tab back, I get this.
Also, is it supposed to start at the music screen and not the home screen?
Major speed improvements.... Once everything is loaded, screens switch instantly on my M10000... Also I got rid of all the redraw problems, except still working on the video/dvd... The "enhanced graphics" option in setup doesn't do anything anymore, not neccesary.
I also fixed the weather temps being switched, the dvd volume buttons drawing improperly, and the problem with occasional messed up buttons on the bottom nav during the initial load...
Download here:
http://www.fluxmedia.net/downloads/cf-beta1.11.zip
This is just a binary update and only includes the centrafuse.exe. Just overwrite your current centrafuse.exe with this one.
david
Check the option in your settings.... Is auto launch music enabled or disabled? Try toggling it and re-writing your XML...
david
That fixed it... thanksOriginally Posted by veetid
BUT, if I got to the music manager, and to the albums and find an album that has album art, and the next one doesn't, the album pic doesn't disappear.
0l33l: I fixed it and updated the link above...
david
Yes, its fixedOriginally Posted by veetid
About the first drawing error. I noticed that it happens when I tab into CF. If I click on the task bar then everything is ok, but if I alt-tab I get that drawing anomaly.
0l33l: Is the drawing problem only when tabbing back to the weather screen? What about on other screens?
david
has the destinator bug been fixed . i.e not refreshing the map ?
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall returnThe car
This is the other screen I found it on. I do get a small artifact on the music selector as you could see in one of the other pics.Originally Posted by veetid
I've got another drawing problem, when I go to GPS with my embedder application, when I switch back to radio or mp3 I can se both the radio stations and the mp3 controls on the buttons bar. I think the picture explains it
don't bother for the embedding problem, I have it only on one pc and I suspect it's an "on top" problem or something like this. on the other pc I've no problems with embedded apps
another thing, the program starst on the main menu, but if I switch to radio and then back to main menu it redraws this (the first time)
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
