Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Anyone Destinator working in Centrafuse ?
  1. #11
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Angry
    You mean "GPS Path" in CF setup?
    C:\DestinatorApps\Frontend_BETA3\Destinator3.exe
    GPS window name:
    Destinator 3 - [Dest3.1]
    Attached Files Attached Files
  2. #12
    Constant Bitrate superbowl's Avatar
    Jan 2005
    Germany
    Hi,
    tested nearly every combination and get a little more confused.
    I tried my system running in 800x600, 800x480, 32 bit color, 16 bit color, and all possible combinations, but still the embedded map wonīt move.
    To confuse myself even more, the name of street where i am driving - displayed in the info-bar in the top of the destinator window - is updated very fine, itīs only the map ! so.. the windows does not completely freeze, it is the map.
    I guess iīll send ninja a pm... maybe the fault is on d3īs end ?
    - stefan
    i never drink water cos fish ***** in it. (w.c. fields)
  3. #13
    May 2003
    Czech rep.
    Quote Originally Posted by mpattonm
    GPS window name:
    Somebody please tell me what am I doing wrong.
  4. #14
    Constant Bitrate weekendowel's Avatar
    Jan 2004
    Stockholm, Sweden
    I donīt now what you are doing wrong, the settings seems to be right, does destinator start at all?
  5. #15
    Constant Bitrate skydiver's Avatar
    Nov 2004
    southampton (UK)
    my destinator starts and run purfect on its own and it embed's fine but as you say the map just doesnt move when you drive or move it with mouse. the map will only update if i touch the zoom slider but that's just one frame
    I think these two peaces of software are the best out there and i must have
    please help us Ninja and Veetid
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
  6. #16
    Maximum Bitrate knubile's Avatar
    I'm having the same problem. I had it working before with older versions. I reinstalled the OS on my system and all software. Now I can't get it to work.
    I have NM's front end set to not set size and position.
    pointing to destinator3.exe
    window name Destinator 3 - [Dest3.1]
    Destinator works and runs just fine when I click the gps button in CF, it just won't embed into CF.
  7. #17
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    try changing the remeber size button i got that off.
  8. #18
    did. no dice.
    How does CF actually try to embed the window? Does it keep searching for a certain amount of time then give up? Is it possible it's taking destinator too long to load?
  9. #19
    Sep 2003
    Gloucester (UK)
    well it works for me and I've no idea why.
  10. #20
    Thanks for the suggestion anyways.
  1. XPsp2 volume slider erratic using Centrafuse
    By Nickernack in forum Centrafuse
    Last Post: 01-31-2005, 11:34 PM
  2. New Release CENTRAFUSE 1.1
    By veetid in forum Centrafuse
    Last Post: 01-18-2005, 10:17 AM
  3. Centrafuse and Vob files
    By chuckster in forum Centrafuse
    Last Post: 01-17-2005, 04:26 PM
  4. 640 x 480 skin for centrafuse?
    By ProCos in forum Centrafuse
    Last Post: 01-16-2005, 01:00 PM
  5. D3 embedded in Centrafuse : no OSK
    By superbowl in forum Map Monkey
    Last Post: 01-02-2005, 09:12 AM
