Results 21 to 30 of 32
Thread: Anyone Destinator working in Centrafuse ?
  1. #21
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    when my car comes back I'll list all the options of Desintator and CF and see if that helps.
  2. #22
    Constant Bitrate slffl's Avatar
    Jan 2004
    Are you running in 'navigation mode'? The map doesn't move in 'planning mode'.
  3. #23
    VENDOR - Centrafuse veetid's Avatar
    I just installed it and it embedded first try... No problems at all... Using the window name everyone else is using.. Not sure why some people are having problems... I am just at my desk though, so I am not sure about the map update problem...
    david
  4. #24
    Constant Bitrate skydiver's Avatar
    Nov 2004
    southampton (UK)
    @veetid you can tell just by trying to move the map with the mouse.if you have the problem the map wont move
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
  5. #25
    Maximum Bitrate knubile's Avatar
    Embeds first try!?!? Damn. What's wrong with my setup!??
    I'm using what everyone else is.
  6. #26
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    I am jsut strarting suspecting nLited OS.
  7. #27
    Jan 2005
    I can't get it to work. D3 embeds fine, but no matter what I do, the screen won't update. Most other apps I try to embed updates fine, so I believe the problem lies with D3. CF has problems with closing certain apps though... I believe it's mostly apps that have requesters when quiting, i.e. "Do you want to save", like M$ AutoRoute/S&T.
    D3 works very well when stand-alone though...
    EDIT: I have disabled firewall and have no AV running. Win XP Pro SP2 - English. Regional settings Norway.
  8. #28
    Low Bitrate Kato's Avatar
    Oct 2003
    Toronto
    I'm getting the same screen freeze on the map windows. Bizzarre...won't update the map as i drive. Original version seemed to be ok with it.
  9. #29
    Jun 2004
    The North, Manchester
    map frozen here too
  10. #30
    Dec 2004
    Frozen Maps with Destinator 3 also
    Maps will not move as i drive. Speed changes based on actual velocity, but map position doesn't update when embedded. D3 works fine when launched independently. Please help.
  1. XPsp2 volume slider erratic using Centrafuse
    By Nickernack in forum Centrafuse
    Last Post: 01-31-2005, 10:34 PM
  2. New Release CENTRAFUSE 1.1
    By veetid in forum Centrafuse
    Last Post: 01-18-2005, 09:17 AM
  3. Centrafuse and Vob files
    By chuckster in forum Centrafuse
    Last Post: 01-17-2005, 03:26 PM
  4. 640 x 480 skin for centrafuse?
    By ProCos in forum Centrafuse
    Last Post: 01-16-2005, 12:00 PM
  5. D3 embedded in Centrafuse : no OSK
    By superbowl in forum Map Monkey
    Last Post: 01-02-2005, 08:12 AM
