Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 60
Thread: NEW CENTRAFUSE Update 1.12
  1. #11
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    Thanks, I got a copy of it too!
    Quote Originally Posted by camsgs3
    Its a couple of posts down, HERE
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
  2. #12
    Constant Bitrate superbowl's Avatar
    Jan 2005
    Germany
    Hi David,
    great work !!! My videos and dvds are playing as smooth as silk right now. great. now i only need d3 embedded working ;-)
    - Stefan
    i never drink water cos fish ***** in it. (w.c. fields)
  3. #13
    was Boston -> now Canada!
    Please....Is there anyway to not have music start playing automatically on start? My playlist starts as soon as Centrafuse loads and I don't want them too.
    Thanks,
    Chuck
  4. #14
    Oct 2004
    Netherlands
    Quote Originally Posted by mpattonm
    BTW There is a strange problem on first launch. Even if I select stretched 800x600 skind during initial config dialog, CF starts in 800x480 with all the interfece segments messed up. I have to quit the interface and launch it again. This time it runs correctly. And I STILL CANNOT LAUNCH DESTINATOR3 EMBEDDED no matter hwat I do set up CF and Dest3 front end like.
    works fine here, which windows are you running?
    my destinator map resource down permanently
  5. #15
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    is there a reason why when i replaced the centrafuse 1.11 exe with the 1.12 exe, centrafuse opens up on my taskbar and then never opens up and then freezes my carpc (which causes me to do a ctrl-alt-del and end task) ???? should i just do a complete reinstall? hmmmm any ideas veetid?
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  6. #16
    VENDOR - Centrafuse veetid's Avatar
    mpattonm: I do plan on adding tabbed browsing, but not sure on the time frame... Other things are in front of it.. Like integrated D3 and OBD, which are coming soon. I will also look into the strange draw problem on initial load...
    TuneVitesse: Currently you can't add voice commands. Come up with a list of commands you think I need to add and I will get them added for you. Also, thats a good idea about a voice popup... I will add that in utiltities...
    External apps support is going to be in the next version....
    chuckster: I will add an option to enable/disable whether music starts when you you launch centrafuse...
    Chita79: I have no idea why that would happen... Try downloading it again, rebooting, and overwriting it again... Should work...
    david
  7. #17
    Constant Bitrate skydiver's Avatar
    Nov 2004
    southampton (UK)
    integrated D3 that will definatly solve the embeding probs i am having how soon for that ver david
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
  8. #18
    Quote Originally Posted by veetid
    Awesome! Thanks David.
    Chuck
  9. #19
    Feb 2004
    donīt know if this has already been posted but i have a little probles...first of...when playing music, i sometimes (quite often actually) hear some noises that arent in the song...most often on bass beats or similar...extra sounds generated by the software i think because i dont hear them in winamp or WMP...second of...when embedding D3 everything works fine, switching to fullscreen also, but when i get back from fullscreen, the buttons on the side and bottom are redrawn...missed the buffering there?
    and last, and i dont know if this is because of your software but, when the GPS window with D3 started gets ontop of another window, i get graphic errors cause i can still see the gps window on the window being under it when moving that window...
  10. #20
    I fixed the problem with changing the skin in the initial setup causing drawing errors. I updated the link and the full install on the web...
    david
  1. XPsp2 volume slider erratic using Centrafuse
    By Nickernack in forum Centrafuse
    Last Post: 01-31-2005, 10:34 PM
  2. CENTRAFUSE Update 1.11
    By veetid in forum Centrafuse
    Last Post: 01-25-2005, 06:59 PM
  3. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 09:17 AM
  4. Centrafuse and Vob files
    By chuckster in forum Centrafuse
    Last Post: 01-17-2005, 03:26 PM
  5. 640 x 480 skin for centrafuse?
    By ProCos in forum Centrafuse
    Last Post: 01-16-2005, 12:00 PM
