do you need to have loaded 1.11 first?
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
I always get the error when I shutting down CF with destintator loaded. I'm going to record the error messge and pass it to Ninja monkey when I get my car back from the garage after its spray job to me new bumper.
bertybassett: you don't have to have 1.11 loaded, just overwrite your current exe with this new one and you should be good. Ninja posted in a thread in this forum and I thought he said his Hotfix #3 would fix his closing problem.
antimater: Weird... iGuidance 2 is what I personally use and I have never had a problem embedding it. iGuidance is the window name you should be using, unless it is different on Windows2000. I have never run CF on 2000, only XP.
david
I will give it a shot on my car pc which is running XP Pro. I hopefully will have better luck. BTW i really like your program. The only things missing IMO are Remote Control Access (which can be done with Girder i suppose), XM and an External Applications module.Originally Posted by veetid
All in all great application
The skin problem was only the first time you change the skin. A restart of CF solves that. My guess is that CF doesn't erase the text.Originally Posted by veetid
CF is currently running very fast on my 2.5ghz p4 machine with 1gig of mem. And the weird artifacs are still present.
:veetid I've got hotfix 3 loaded and still it's no good when exiting CF.
bertybassett: I will ask Ninja about it. I am currently talking with him to try and figure out the refresh problem... Worst case I will just add a Kill process in my code, which should kill it for sure... Right now I just attempt the proper close, but Ninja's app doesn't seem to want to close and hangs both applications...
david
