Page 6 of 6 FirstFirst 123456
Results 51 to 60 of 60
Thread: NEW CENTRAFUSE Update 1.12
  1. #51
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by veetid
    Ninja Monkey: It just sends the WM_CLOSE... I have run and properly closed the following apps iguidance, routis, mappoint, photoshop, flash mx, notepad, word, and excel... The only two programs I have ever had a problem with closing are Ninja D3 frontend and PhoneControl, it has closed everything else I have ever run in it. I can look into calling the lower level WM_CLOSE myself, but .NET's Process.Close is suppose to do just that and it works for every commercial app on my machine...
    david
    Use winsock to send the quit command. But then it wouldn't work when you have NaviVoice running
  2. #52
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    david
    I created a very basic VB app and exactly the same happened.
    And then with my D3 launcher, It checks to see if centrafuse is still running and if not will close itself, but when you exit CF the app seems to get locked up by your close message and will no longer check.
    If I send a WM_CLOSE to any of these apps they close fine. What gives?
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  3. #53
    Dec 2004
    IMHO it seems that if one app (D3) is checking if the other (CF) is up in order to close itself. And the second app (CF) is tryning to send a close app on close. It can lead to much confusion depending on when the requests hit the OS. IT ewould be interesting to see if the close command from CF will work if D3 is not checking on the state of CF.
  4. #54
    Aug 2003
    Warrington, UK
    D3 doesn't check to see if centrafuse is running, the launcher I created today does and this issue has been around way longer than that.
    And it's nothing to do with D3 itself because like I said, i've tested it with a blank VB app
    So, er, try again
  5. #55
    VENDOR - Centrafuse veetid's Avatar
    Ninja Monkey: I have your D3 installed and embedding now, so I will test out some new closing methods and see if I can come up with anything. As of now, sending the Kill command fixes the problem and works... I have an idea of another way to close out my stuff and I will see if this works first. If not, I will just release the version that sends Kill. I didn't notice any adverse affects from it...
    david
  6. #56
    Tainted Love Cris's Avatar
    Romania
    Just installed it...Impresive, it's a lot faster...David, great job again man. Really, I wouldn't know what to expect from the next release...
  7. #57
    Dec 2004
    My mistake, just trying to help. Good luck guys.
  8. #58
    New York
    Nother issue is lack of memory. I myself don't run a DC-DC timer sol'n, nor do I ever shut down windows properly. When I pull the key out of my car. The computer shuts. Most of the time, I let the computer shut down with Centrafuse still running. When I boot it back up, it never comes back to the last played song or location and never to the last Video played. It always reverts back to the top of the playlist. WOuld be nice to have some kinda of track of the last song played or something so i am not always listening to the same song non stop. Thx.
  9. #59
    New York
    Another issue. Start up Centrafuse, video, playlist, clear playlist, and something to the playlist. Load it. Start playing. Then shut off carputer rapidly. When you restart the carputer, centrafuse doesn't keep in the modified paylist but the old playlist instead.
  10. #60
    DaRacerz: Both of your problems are related to the fact that I didn't save out current session information on shutdown, only on the click of the exit button. It was an oversight, since I mainly use hibernation. This has already been fixed and will be in the next release
    david
  1. XPsp2 volume slider erratic using Centrafuse
    By Nickernack in forum Centrafuse
    Last Post: 01-31-2005, 10:34 PM
  2. CENTRAFUSE Update 1.11
    By veetid in forum Centrafuse
    Last Post: 01-25-2005, 06:59 PM
  3. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 09:17 AM
  4. Centrafuse and Vob files
    By chuckster in forum Centrafuse
    Last Post: 01-17-2005, 03:26 PM
  5. 640 x 480 skin for centrafuse?
    By ProCos in forum Centrafuse
    Last Post: 01-16-2005, 12:00 PM
