Page 1 of 6 123456 LastLast
Results 1 to 10 of 60
Thread: NEW CENTRAFUSE Update 1.12
    VENDOR - Centrafuse veetid's Avatar
    Another binary update. Just overwrite your current centrafuse.exe with the one in the following zip file.
    http://www.fluxmedia.net/downloads/cf-update1.12.zip
    Or visit http://www.fluxmedia.net and download the full install in the centrafuse downloads section.
    Made a few more optimizations. Should run really fast now. I fixed the display problem with the bottom nav, when switching between music and radio modes. I also think I might have fixed the video player problems. It was also jerky on my machine and the changes I made cleared it up. Hopefully it was the same problem.
    Note: Still working on the redraw of the buttons in the video/dvd modes...
    david
    Constant Bitrate skydiver's Avatar
    Nov 2004
    southampton (UK)
    just tryed it and fast is no the word
    great work david
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Same weird alt-tab problem Changing skins causes weird drawing errors
    Otherwise it works great
    0l33l: I just updated the link... I fixed the skin changing problem... What speed machine is giving you that alt-tab redraw?
    note: you can remove the text on the left buttons on that skin so that it just shows the icons. Look in the skin.xml file and under global nav set enabletext = false for all those buttons...
    david
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    0l33l - Any way I could get a copy of your brushed metal skin?
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Hi veetid, do you plan .NET free version? Have you also already included. button tabbed-browsing support in your time plans?
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    How do I add more commands to the voice control, it works really well with my new noise cancelling mic...
    I know the commands are in ..\system\grammar.xml but I'm not sure how to actually add new commands, such as Settings, Hibernate, or Music Manager, voice scroll up/down lists... Or even better, a page in settings where voice commands can be listed and allocated easily by anybody. I think it would also be handy to include a command that would list all the available voice commands in clear text in an embedded browser window for people like me with bad memories.
    Also now that Ninja Monkey has made the D3 front end SDK D3TALK available, couldn't CF be made with D3 built in and also able to be controlled by voice.
    Another request would be links to the PSD files for your skins (Blue/Red & Black/Green) so I can add my car logo to them...
    Other than that David, GREAT PROGRAM, I'm very impressed, only thing thing that appears missing for me now (unless I've missed it) is external apps support...
    John
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    Tuned Vitesse,
    What kinda mic are you using?
    May 2003
    Czech rep.
    BTW There is a strange problem on first launch. Even if I select stretched 800x600 skind during initial config dialog, CF starts in 800x480 with all the interfece segments messed up. I have to quit the interface and launch it again. This time it runs correctly. And I STILL CANNOT LAUNCH DESTINATOR3 EMBEDDED no matter hwat I do set up CF and Dest3 front end like.
    Jan 2004
    NYC
    Quote Originally Posted by BeaverWise
    Its a couple of posts down, HERE
  1. XPsp2 volume slider erratic using Centrafuse
    By Nickernack in forum Centrafuse
    Last Post: 01-31-2005, 11:34 PM
  2. CENTRAFUSE Update 1.11
    By veetid in forum Centrafuse
    Last Post: 01-25-2005, 07:59 PM
  3. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
  4. Centrafuse and Vob files
    By chuckster in forum Centrafuse
    Last Post: 01-17-2005, 04:26 PM
  5. 640 x 480 skin for centrafuse?
    By ProCos in forum Centrafuse
    Last Post: 01-16-2005, 01:00 PM
