Hi,
this is a known issue and ninja is working on it.
- superbowl
I am still having problems with D3 embedded in CF 1.12, just downloaded update again today to make sure it was the later version.
I am having Refresh problems. When I first Open CF, I then click on the GPS button. D3 now opens. The buttons all to the left of the View button are not showing, when it first opens. I then click on the Music Button, and then back on GPS. I now can see all of the buttons. I then Exit out of CF and the D3 Map is still showing on my Display. It is not refreshing this correctly, so it is closing it all the way. If I do a CTRL+ALT+DEL, D3 is still shown as running, so it doesn't seem to be closing correctly for me.
Now when I run D3 outside of CF, it seems to work fine.
Is anyone else having this type of Problem?
thanks,
Bryan
2000 Yukon Denali
Shuttle SN65G2
Cel-D 2.4 GHZ 533mhz FSB
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
RF Mini Kb w/Trk Ball
7" Lilliput Touch Screen Monitor
USB 2.0 Hub
Rikaline GPS-6010
PN11 802.11b Wireless
XP Pro
750W Inverter
Hi,
- superbowl
i never drink water cos fish ***** in it. (w.c. fields)
Just so that everyone knows, I was using the Stretched Skin 800x600, but changed to the 800x480 and the buttons showed up correctly, when D3 first opened. But it still seems that it is not refreshing correctly when you go to Full screen, by clicking on the Top of CF, then click it again, I again lose my buttons to the left of the House button this time.
It seems to be better under the 800x480 resolution than it is under the 800x600. Also I tried the other buttons and they all seem to allow it to refresh correctly. It only seems to be when you click on the Title bar to make D3 go full screen, and then when you click this again to bring CF's buttons back up, under the 800x480 mode. The problems still all exist as described above in the post under the 800x600 mode.
Just thought this might help find the issues.
Thanks,
Bryan
2000 Yukon Denali
Shuttle SN65G2
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
USB 2.0 Hub
Rikaline GPS-6010
XP Pro
750W Inverter
Sorry for all the posts in the same thread, but I just noticed another glitch. In 800x480 the weather doesn't work correctly. It shows the Current Conditions correctly, but then the 4 Day forcast is not showing as normal. It shows Friday: then the 2 temps, and that is it. This also happens under the 800x600 as shown below in the image.
2000 Yukon Denali
Shuttle SN65G2
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
USB 2.0 Hub
Rikaline GPS-6010
XP Pro
750W Inverter
bry21317: Give me the postal code you are using for weather because I can't reproduce this problem. Might be related to the data from your region.
david
It is 27616, it is working fine today. Must have just been a glitch the day that I was testing it.
Thanks for the response. Sorry for the delay.
Bryan
2000 Yukon Denali
Shuttle SN65G2
1GB PC800 Mem
Radeon9200 PRO
Seagate 120GB
ATI Remote
USB 2.0 Hub
Rikaline GPS-6010
XP Pro
750W Inverter
