Results 1 to 9 of 9
Thread: CD Ripping errors out...with screenshot
    Oct 2003
    I don't know what's going on here - I'm not able to get the CD ripping to work. This is on a clean SP1 install. Am I missing a needed component? Attached is the error message I get, then Centrafuse quits.
    Thanks!
    Dan
    Edit: DVD doesn't work either. Centrafuse either freezes, or it just jumps from title to title, chapter to chapter, but nothing on the screen. I installed PowerDVD because I thought it needed the codecs, could this be interfering?
    VENDOR - Centrafuse veetid's Avatar
    Does it give this error with every CD you try? Did you try more than one? Same for DVD.
    david
    Oct 2003
    David-
    No CD was in the drive when I tried this - is there supposed to be one in there first? If so, I'm an idiot.
    As far as the DVD though, yes I did try multiple discs and it does the same thing. Not sure what's up...
    Dan
    Oct 2003
    Just tried it with a disc in the drive - no go...
    Nevermind...I'm a fool...didn't have the drive letter in. Let me try a DVD now...
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by dmurray14
    David-
    Dan
    It's the cake having/eating thing.
    Oct 2003
    OK, the CD ripping works now, but I must have one slow *** reader, cause it takes about 2.5 minutes to do each song...
    Autoplay doesn't work though...I'll have to look around with that before I ask for help
    Oct 2003
    Argh....OK so the CD ripping is working (albeit SLOWLY, but that's probably the drive?) but DVD is still screwed. Tried uninstalling PowerDVD but that didn't make a difference. Not sure whats up...any clues?
    Oct 2003
    Any ideas on the DVD problem? This is REALLY annoying. What codecs are you all using? Anything special I need to do to get DVD working right?
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    uninstall all dvd player software
    install only powerdvd, then search for *.ax filters in your pdvd dir and in \system and subfolders, there are 2/3 ax filters involved in dvd decoding, something like mpeg2dec.ax if I remember correctly. keep those filters in a secure place and uninstall powerdvd
    then copy those ax filters in \system dir and perform a "regsvr32 filtername.ax" for each file
    now you should run fine with only the decoding filters and no other stuff
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  1. CD Ripping embedded!
    By RoyN in forum NeoCar Media Center
    Last Post: 11-06-2004, 06:12 AM
  2. Good CD Ripping Utility?
    By infinitifanatik in forum Media Engine
    Last Post: 10-11-2004, 02:34 PM
  3. Strange problem - pc shuts down when ripping audio cd.
    By tbird2340 in forum General Hardware Discussion
    Last Post: 09-13-2004, 10:24 AM
  4. Cd Ripping and CDDB
    By OriginalNick2 in forum Media Engine
    Last Post: 07-09-2004, 06:42 AM
  5. Autoplay ripping CD to MP3?
    By JrFaust in forum Software & Software Development
    Last Post: 03-05-2001, 10:10 PM
