Results 1 to 10 of 12
Thread: Centrafuse 1024 x 768 skins?
    Dec 2004
    UK
    Searched already but no joy- anyone know where I can get this?
    Thanks in advance
    Dec 2004
    UK
    bump
    anyone??
    Mar 2004
    from what I have heard, you have to manually create the changes, both to the images and xml files.
    I have yet to dive into it, but I definately want to customize my screen for 800 x 480.
    Check here
    Constant Bitrate Meta's Avatar
    Dec 2004
    Indiana
    Quote Originally Posted by Coeus
    Check here
    It's really not that hard... just time consuming. If you don't have it already, go download the trial version of PaintShopPro. Then go through each of the images and resize them to whatever dimensions you want. Then, in PSP, use the SELECT tool to draw boxes around each button/hot-spot/clickable-area and note the X,Y, length and width. Put those values into the appropriate spots in the skin.xml file.
    There's probably a better tool out there, something for automatically making image maps or something, but I haven't looked around much.
    -Meta
    Mar 2004
    That sounds fairly easy, but I definately want to do a custom skin. Maybe when I get some free time. Other bad thing is that CoPilot LIve 8 does not work so well in Guidance mode at 800 x 480.
    Oh well.
    Nov 2004
    St Louis
    Oh well.
    Don't worry, it won't end up that big. And with Centrafuse you can reesixe it to whatever you want in the .ini file.
    Mar 2004
    Quote Originally Posted by GizmoQ
    what won't end up that big?
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Oh well.
    So have you figured out how to resize the screen/buttons for Copilot 8 in guidance mode? I was looking at the ini files in the app directory, some of them looked promising...
    VENDOR - Centrafuse veetid's Avatar
    you don't need a new skin... Just fill in 1024 for the width and 768 for the height in setup...
    david
    Raw Wave justintime's Avatar
    Apr 2005
    I guess what he is really asking for, is a 4:3 native skin file. If he goes fullscreen with the WS skin, it will look distorted, no?
    Quote Originally Posted by veetid
    david
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  1. Skins, skins, skins and... skins (and NOTHING MORE)
    By netsuo in forum NeoCar Media Center
    Last Post: 12-21-2005, 08:12 AM
  2. Centrafuse Launcher (Fixes Map Movement)
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-02-2005, 03:53 PM
  3. Centrafuse and Vob files
    By chuckster in forum Centrafuse
    Last Post: 01-17-2005, 04:26 PM
  4. 1024 x 768 skin
    By WebDog in forum Centrafuse
    Last Post: 12-12-2004, 01:41 PM
  5. 1024 * 768
    By Parag0n in forum FrodoPlayer
    Last Post: 06-13-2004, 10:46 AM
