Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
Thread: Performance Issues
  1. #41
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Im using an M10000 as well and its quite slow
    Slow enough for me to notice it but not slow enough to get too ****ed at
    I like CF so Im living with the slow speed
    If you can make it faster though....Id be all for it! Id heavily consider paying for the software if the speed was brought up to a reasonable level
  2. #42
    FLAC SFiorito's Avatar
    May 2004
    sorry, but i'm coming into this a bit late. just wondering if any of you have tried ngen? it basically creates a native image of the .net executable and installs it in the gac (global assembly cache). it should at the very least make it start up faster. i don't use CF, but I know this is a good trick sometimes for heavy .net client-side apps.
    http://msdn.microsoft.com/library/de...torngenexe.asp
  3. #43
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    hum
    really dunno what you're taking about but if anyone tries it I'll be glad
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  4. #44
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    I gave it a try but got an error messsage. Maybe it was my syntax:
    ngen centrafuse c:\centrafuse\centrafuse.exe
  5. #45
    May 2004
    the syntac would simply be:
    ngen path_to_exe
    When you install a new version you MUST delete it from the GAC. Either use "ngen /delete path_to_exe" or just use explorer and go to the "C:\Windows\Assembly" directory.
    Only thing is, if there are other .net dll's that it uses you should make native images of those too. Read that document I linked, it's got the full details.
  6. #46
    Aug 2003
    Federal Way, WA
    Quote Originally Posted by SFiorito
    ngen path_to_exe
    I did read it, but most of it is over my head. The first line shows "ngen [options] [assemblyName |assemblyPath ]" thats why I went with "ngen centrafuse c:\centrafuse\centrafuse.exe" I'll give you're suggestion a try and let you know what happens.
  7. #47
    Constant Bitrate ApoloV's Avatar
    May 2003
    Virginia
    TimmyM the syntax you used is if your executable is in the current/active directory, which it wouldnt be..
    Use
    ngen <path to exe> and it will run..
    However i tried this and my frontend crashes (granted i use AutoTouch but in principle it should be the same)
    I think its because you have to ngen each assembly or dll that the frontend uses?
    Not a programmer here, but any info would be good info
    Apolo
    2002 DSM RSX-S
    Custom Car PC Re-design Pending Completion of fiberglassing dash and trunk
    Pics
  8. #48
    Jul 2004
    NL, Druten
    And that's why I don't want an epia...
    Installed one last week for a friend, it's just too slow.
    My install? P4@2400-512MB-80GB-OPUS 150W-7" motorized indash screen!!
    I rest my case.
  9. #49
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    You people do realize this thread is 5 months old and is not about the current CF release right?
  1. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 01:16 PM
  2. Performance Mods
    By fluffy2097 in forum Off Topic
    Last Post: 07-27-2004, 09:57 PM
  3. Legality issues
    By cadence117 in forum General MP3Car Discussion
    Last Post: 04-26-2004, 05:19 PM
  4. Lilliput 7" VGA and EPIA M9000 issues...
    By heat in forum LCD/Display
    Last Post: 01-15-2004, 03:57 PM
  5. Do ISA Cards lower the performance of a PC ?
    By felix99 in forum General Hardware Discussion
    Last Post: 11-05-2002, 04:37 PM
