in the CF configuration wizard you can specify an external radio tool and a window name, that's all you need for embed any program, the last step is to modify the skin xml file, remove "RADIO" label and put whatever you like
I don't have a radio card or XM radio on a system and would like to have a button on CFuse open/embed an application called TopoUS ( topographical GPS )
I know that I can run it along with Destinator / MapMonkey as I have a port splitter for the GPS antenna.
I looked through all ini/xml files and could not find where to do it..
If it was staring right at me, I am sorry for being an idiot
Thanks in advance for any help
Don
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
actually modify the language file to just change the text from Radio to something else..
david
that's what I mentOriginally Posted by veetid
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
Worked great !!!
The only issue is when I have the 3D map AND the 2D map displayed ( Topo USA ) side by side, the 3D screen flickers when embedded in CFuse and doesn't do it while it's a standalone.
Dest3.1 & TopoUSA work at the same time due to com port splitter and having TopoUSA in place of "Radio" button is great since I am using my HU for radio
Thanks again guys, yet another successfull tweak, now I just gotta get the weather screen to use Port:8080 ( BT cell T-mobile proxy )
Here are some screen shots of what it looks like
sorry for multiple posts as only one will show up
First what it looks like as a standalone w/ 3D view enabled
now some other shots
with buttons and Topo info bar
with buttons and no Topo info bar
without buttons and Topo info bar
without buttons and fullscreen
