Results 1 to 9 of 9
Thread: question about weather screen and port 8080
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    If I am hooked up to a LAN or over 80211 the weather screen works great.
    If I connect to my phone(BT): IE works, Firefox works, traffic screen works, but weather screen does not work.
    When I am using BT over cell phone I have to use a proxy server on port 8080 because T-Mobile blocked t-zone internet access for free, so the workaround is port 8080..
    anyway, whats the source of the weather page and how can I configure it to work.
    Also, wondering if others are having this problem.
    Thanks again
    Don
    VENDOR - Centrafuse veetid's Avatar
    All providers I have used have atleast port 80 open... Not sure about how to make a work around for this 8080..
    david
    Feb 2004
    North Aurora, IL
    nah, tmobile just recently blocked port 80 about a couple of months ago on their tzones (4.99) plans, you have to get the more expensice internet plan to get port 80 open (19.99).
    id like to know this since i have the same 4.99 tzones plan that has port 80 blocked.
    May 2004
    here's the info from another thread
    http://www.mp3car.com/vbulletin/show...0&postcount=84
    David : Maybe you can incorporate some sort of specifications in the seting in the future releases..
    The web window works, so maybe we can store page locally and access it through web window which would get info from current connection ( short term fix ? ) The weather page is great and would just like to utillize it. I'm sure that many will have this problem as there are many people using T-Mobile that have the 4.99 T-Zones not the ( 4.99 + 19.99 ) expensive plan.
    Thanks again
    Don
    May 2004
    bump de bump
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    have you guys thought about running a simple proxy on the same computer? im not very fluent with it neither have i used a proxy before, but iirc you can make it to translate ports (access to port 80 goes to port 8080).
    do some searching and im sure you should be able to find a quick solution to this dilemma.
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    Yeah, i've got this issue as well. I'm assuming its due to the fact that we're proxying port 80 traffic. A bit off topic, but i noticed the port 8080 connection doesn't allow direct access to servers via ip address either.
    May 2004
    Quote Originally Posted by Vchat20
    the ISP ( t-Mobile ) blocks port 80, so no matter what we do the only accessable port ( at the ISP ) is port 8080 through a certain proxy IP 216.155.165.50
    Jan 2005
    Warren, Ohio, USA
    thats what i meant. since the weather page seems to be locked to port 80, you should be able to run a proxy on the carputer which will translate all access to port 80 to port 8080 which will essentially make the weather page use port 8080. but if david is going to add more configuration for this, then more power to him.
  1. Replies: 6
    Last Post: 10-20-2004, 11:23 PM
  2. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-14-2004, 12:29 AM
  3. Replies: 11
    Last Post: 12-02-2003, 08:29 AM
  4. connecting LCD screen to printer port
    By coupeman in forum LCD/Display
    Last Post: 10-30-2002, 09:50 PM
  5. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
