Didn't work. I remember everything working before 1.12.Originally Posted by scott_fx
i doubt this is any new info for 0l33l but i added 'm4a' file format in the xml configure doc (after adding the aac codec) and CF loaded all my songs. could something like that be your problem?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
dscaler seems to work perfectly embedded, it only lacks the buttons mentioned before. it's opensource and supports almost every tv tuner, I think you could really use this like you do with radiatorOriginally Posted by veetid
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Offer a ZIP download and I'll give the beta a try.
1997 Toyota Celica
ehm it IS a zip download have you even tried to go to the link?Originally Posted by mportobello
http://www.centrafuse.com/software/
http://www.fluxmedia.net/downloads/cf-beta1.20.zip
stuff you will need: http://www.centrafuse.com/software/centrafuse.aspx
my destinator map resource down permanently
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
Got same problem with GPS and Radio. Embedded apps have to load 2 copies before CF realizes its open. Tried using Street Atlas, IGuidance, Xtreme PCR, and WinTV2K. anything I embed doesn't look lik it embeds the first time but if I change to MP3 and back its there, wait a few seconds and second instance starts up. As long as second instance doesn't take over full screen I can ignore it and original instance works perfect, but its eating up al my memory and the second instances (especially GPS) eats up all my clock tics, i.e., CPU usage 100%.Originally Posted by dodgetimes2
hum, no problems of this kind for me
but when I quit cf in the application bar I still see the embedded program iconized, once I click on it it disappears. Not really a problem
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
I will check into this relaunch problem with my embedded apps... I tested it with iGuidance before I released and it appeared to work ok... I will figure out why it doesn't see the app... It should know there is already an instance running and just maximize it, not relaunch the app...
david
I meant available without a setup program. xcopy deployment.Originally Posted by GReeToZ
1997 Toyota Celica
