If you are using radiator then it doesn't matter what you put in the window name field, that is only for people using external radio programs. Make sure you hae "Use Radiator" enabled.
Make sure radiator is closed and then launch CF. When you click Radio does it startup radiator? If so then you know the path is right. Then try and tune frequency and see if the radiator frequency changes...
Also make sure rc.exe is located in the same path as the exe you specified in the "\Add-ons\Command line" sub folder.
david
LinkBack URL
About LinkBacks
