Results 1 to 8 of 8
Thread: Destinator 3 / D3 Installation
    SOS
    SOS is offline
    Jan 2005
    Now there is a ton of post explaining what and how to implement D3 into CF etc.
    But for us newbies itīs pretty difficult to find any information about HOW to install D3 so that it works with CF :-) You guys all seem to have this figured out, so please share....
    I have D3 for my PDA, and since it is not being produced for PC anymore, I assume this is the version you are all running, but how? Can CF read the maps itself, which PC application is CF calling, any things I should know?
    I also see that I need to buy the SDK?
    Please give a quick:
    1. Install XXX
    2. Install XXX2
    3. Copy Maps to XXX
    4. etc.
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by SOS
    1. Install XXX
    2. Install XXX2
    3. Copy Maps to XXX
    4. etc.
    Email [email protected] and ask him if the SDK will enable you to use your D3 licence and maps on the PC with Centrafuse software.
    He will probably tell you to buy the SDK, make sure when you buy it you state you wish to use it on the PC version.
    They will give you a link and username/password to a SDK - 3.0.75_97_COM_API.zip - you unzip this and copy the DestinatorApps folder to C:\ and copy your maps into the Destinator folder beneath.
    This is NOT ALL you need you WILL also need them to send you a Zip called DestDLL 08-05.zip - which contains DestDLL.DLL which is the Destinator component which will open the full size maps. Once you get this you need to copy it somewhere (say, C:\DestinatorApps\Destinator\DestDLL.DLL) and then run them command "regsvr32 C:\DestinatorApps\Destinator\DestDLL.DLL"
    Once this is done, enable Destinator support in centrafuse and it should work!
    EDIT: There is a PC version on the horizon according to David/veetid however they will not make any unofficial or official statement when it will be released.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Help! I did all this, and London works, but when I try to switch to USA1 I get a popup error: Map not registered. I copied the contents of USA1 off the CD to DestinatorApps/destinator/USA1 and I also put the WCE.txt in there. What went wrong?
    Raw Wave
    Jun 2004
    On the beach
    You are running the demo destdll.dll not the official registered version.
    Apr 2005
    I dont use the new "SDK-mail-version".
    I use the older destdll.dll without the messeages and use destinator 3 Map Cutter for maps from my PDA.
    Works great.
    /RPM
    Nov 2004
    L.A.
    Ok, I found a good copy of Destdll.dll and all is good now. All I can say is WOW! Having a real Navigation system built in to CF totally kicks butt! The maps in D3 are ugly compared to DeLorme, but the functionality is sooooo much better through CF.
    Aug 2004
    do i need to install Destinator SDK for running map monkey or i only need some file ?
    thanks a lot
    alelar
    Aug 2003
    Warwickshire, UK
  1. Problems with D3 Embedded in Version 1.12
    By bry21317 in forum Centrafuse
    Last Post: 01-24-2005, 05:41 PM
  2. D3 problem / embedded
    By btbe in forum MediaCar
    Last Post: 01-21-2005, 05:12 PM
  3. auto loading D3 embedded/hidden?
    By HoSS in forum FrodoPlayer
    Last Post: 12-22-2004, 06:20 AM
  4. D3 with USB GPS after HIBERNATION
    By BOND007BE in forum Map Monkey
    Last Post: 11-26-2004, 02:54 PM
  5. How do I import Speedcam's into D3 1.1
    By CdRsKuLL in forum GPS
    Last Post: 10-25-2004, 08:39 PM
