Results 1 to 10 of 11
Thread: Music problem.
    Low Bitrate 273BeLow's Avatar
    Feb 2005
    Paisley, Scotland
    Music problem.
    can't seem to find anything to help with this.
    CF b1.20
    EPIA M10000
    256Mb DDR2100
    1x 80Gb HDD for OS and apps
    1x 40Gb HDD for Music
    Onboard audio latest and Direct X version
    Currently plugged in to a normal PSU beside me.
    Music just wont work right I get crazy interference it sounds like drum beats and sometimes like a dial toneish sound.
    No idea what to do :/
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Are you currently testing it inside car or outside car audio system? How is your audio out connected to your input device? Through HU or directly to your amp? Through analog or SPDIF?
    You will have to let us know more details man...
    May 2003
    Czech rep.
    I have just realized what forum you posted in. Does it mean you are only having issues under this specific frontend? Did you actually tried playing files that you are having problems with directly from Windows using lets say Media player?
    Feb 2005
    Paisley, Scotland
    the pc is currently beside me set up as a home pc of sorts normal PSU, CRT monitor and 2.1 speaker set up (did the same when I had it plugged in my TV)
    It only happens with Centrafuse. WMP and MediaEngine work fine.
    I have the managed dx thing as well so I have no idea, the only thing I can think is I have heard PCI wifi cards cause problems but I need to use this I dunno if I get a USB soundcard if it might help.
    May 2003
    Czech rep.
    I dont think there is anything wrong with onboard audio. I have been testing CF while ago and I have had no problems with audio quality at all (XP SP2). What OS are you running?
    Feb 2005
    Paisley, Scotland
    Xp Sp1
    I just pulled the wifi card out, same problem.
    Look like the best bet is to get a USB soundcard when I get paiud and see if it helps.
    VENDOR - Centrafuse veetid's Avatar
    It seems something might be wrong with your windows install... Try an old restore point, uninstalling directx and managed directx and re-installing, or maybe re-installing windows itself... You shouldn't have to get an external sound card...
    david
    Feb 2005
    Paisley, Scotland
    Quote Originally Posted by veetid
    david
    Ok then, going to pick up a new 120Gb HDD next weekend when I get paid and order everything else, hopefully that wil lclear it up then.
    Cheers.
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    I read somewhere about codec packs messing with mp3 playback, try to remove such stuff if you installed it
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Mar 2005
    Heidelberg, Germany (1 mile away from hockenheimer ring :)
    odd thing is when i'm playing music on my home pc and my wireless lan card is accesing the hub with something large it sounds distorted have no ide why though
    God, All this <Matt's System > in an '05 760Li Would kick ***
  1. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 01:38 PM
  2. problem with playing MP3 music
    By bigbertha in forum MediaCar
    Last Post: 08-31-2004, 04:42 PM
  3. Line In Mute problem with Radio...
    By ShawJohn in forum MediaCar
    Last Post: 08-20-2004, 05:21 AM
  4. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 11:09 AM
  5. DISH TV music storage project...
    By claylong in forum General Hardware Discussion
    Last Post: 04-16-2003, 09:08 PM
