Get a firmware upgrade to 5.2 for your phone and it will support it correctly.
Hi at all!
Is it possible to write your own plugins? I have a nokia 6230 telephone, but phonecontrol don´t support it correctly because i use a datacable. I use the nokia sdk to communicate with my telephone.
An now my question. Is it possible to write a plugin for centrafuse?
Sincerely BonkersDeluxe
Skinning to go... VisualDesigner2!
Hi zorro
My firmware is 5.24. Is this OK? Do you have an idea to fix the connection problem? I don´t have bluetooth or irda only datacable. I hope you can help me, because i have bought phoncontrol before i get my telephone.
Thanks!
Should be ok. What is the problem with the cable connection?
Thats my configuration.
<Communication id="Nokia">
<Port>6</Port>
<Setting>38400,N,8,1</Setting>
<Vendor>Nokia</Vendor>
<PhoneBookLocation id="1" timeout="60">ME</PhoneBookLocation>
<UseCharset>8859-1</UseCharset>
<UseClip mode="1">True</UseClip>
<UseCPAS>False</UseCPAS>
<UseCLCC>False</UseCLCC>
<UseCNMI mode="2,1">True</UseCNMI>
<UseCRC mode="1">True</UseCRC>
<Keypad quote="False" terminate="False">+VTS</Keypad>
<UseReset>False</UseReset>
<IgnoreMS>True</IgnoreMS>
<SMSStore>SM</SMSStore>
</Communication>
The com port ist the port from the nokia 6230 Modem is this OK?
I get this error : "Öffnen des Kommunikationsanschlußes ist fehlgeschlagen!
Bitte sicherstellen, dass der richte Anschluß verwendet wird."
But "Manuelle Wahl" is possible. Disconnect don´t work
In Phone Test i get the error " {-ResString not found -} "
Thanks!
I think, you're mixing things up.
It's not possible that you dial out if the port is not open. Beside, after this message PhoCo will shut down.
If the port is correct or not, PhoneTest will tell you that. You must not have any other PC-Suite / Connection manager running while PhoCo tries to connect.
I have close all nokia programs.
Why?
Old version
But basically this means "No response". Did you try HyperTerminal?
What is HyperTerminal? How can i use it?
PhoCo Manual, Chapter 10ff
(Note to myself: Don't ever provide a manual again ... it's a complete waste of time)
