Results 1 to 8 of 8
Thread: MP3 Problem in Centrafuse
    Apr 2005
    HI first of all. Total newbie using centrafuse.
    To the problem, when i play a mp3 with centrafuse it makes a really odd popping noise, i played the same file with mediaplayer and it worked perfectly. When playing a movie or a dvd it is fine, it is even ok with a cd. I even went to the extreme of purchasing a 5.1 external sound card but this still has not cleared the problem. SO in a nutshell this only happens with mp3
    Please help if you can, thanks in advance
    Mark
    Apr 2005
    After listening a bit harder it sounds like it has an echo if that helps, but still only does it with mp3
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    maybe a codec issue, did you install something like nimo codec pack or similar? if so, uninstall and retry
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Apr 2005
    Yes i did install nimo codec pack to get the video to play as it requires the codecs. If this is the problem, which codecs are you using for your system ?
    Thankyou for the help
    Nov 2004
    Italy
    single codecs, ffdshow for mpeg4 decoding, windvd filters for mpeg2 decoding
    nothing else for me, if you need other codecs install them one at the time, do not use integrtors like nimo, or at least deselect mp3 codec during installation, maybe it prevent the decoding problem
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Apr 2005
    Thanks for all the help. It was the codecs so i removed them and downloaded just the divx codecs from DIVX.COM.
    Everything is working great now
    Nov 2004
    Italy
    Quote Originally Posted by vwpc
    why not ffdshow? it gives full mpeg4 decoding, so divx, xvid and others mpg4 baset are decoded with no problems. it also includes very powerful post processing filters
    take a look
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    I'm having the same exact issues. Had issues with codecs before, hopefully your solution will work for me.
    -HD
  1. MP3 goes 5.1
    By camsgs3 in forum Software & Software Development
    Last Post: 01-14-2005, 05:43 PM
  2. MP3 CD has issues with MP3 HU
    By Antone in forum Car Audio
    Last Post: 01-04-2005, 03:32 PM
  3. In dash car MP3 CD Costs
    By mp3designer in forum Classified Archive
    Last Post: 02-06-2001, 04:23 PM
  4. Car MP3 Costs???
    By mp3designer in forum General MP3Car Discussion
    Last Post: 01-24-2001, 11:45 PM
  5. Craziest mp3 experience
    By moossmp3 in forum General Hardware Discussion
    Last Post: 12-19-2000, 06:47 PM
