Results 1 to 7 of 7
Thread: Invalid Configuration
    Constant Bitrate Lazyflip's Avatar
    Mar 2005
    FL
    I just downloaded the CentraFuse 1.20 Beta on my computer. I wanted to test it out on this computer before putting it into my CarPC. Everything installed perfectly but everytime I tried to finish the configuration, I would get an "Invalid Configuration" error. Does anyone know what could be the problem. Thanks in advance.
    VENDOR - Centrafuse veetid's Avatar
    Look for an invalid XML character in one of your text boxes... A <, >, &
    david
    Mar 2005
    FL
    Nope. No invalid texts.
    Mar 2005
    FL
    Not really sure what happen, but it all works great now. This is great front end.
    May 2002
    I'm getting this error everytime I try to embed MS Streets and Trips. The window name has an invalid XML character (&) The window name is "Maps - Microsoft Streets & Trips. Does that mean I can't embed this program? Thanks in advance. BTW this front end is amazing.
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    I know that is a problem on the web end of things, so what we do to help xml and xhtml do its thing is to do "Maps - Microsoft Streets &amp; Trips" and it renders that exact offending ampersand correctly, however I don't know if this is the case on the desktop application side of things when using XML, but it is a thought and might be worth trying. Let us know if this works.
    that will work using a &amp; but not in 1.2... I fixed that in 1.3... you can try a %amp in 1.2, that will most likely work...
    david
  1. XM PCR Configuration
    By dragonman in forum Media Engine
    Last Post: 09-12-2005, 02:10 PM
  2. cant change skins???
    By Hell-Stopper in forum FrodoPlayer
    Last Post: 11-05-2004, 11:10 PM
  3. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  4. Replies: 0
    Last Post: 01-16-2004, 08:31 AM
  5. Hardware configuration OK
    By guvi in forum General Hardware Discussion
    Last Post: 10-01-2003, 08:47 AM
