Results 1 to 7 of 7
Thread: What is 1.1 FrameWork
    Low Bitrate scott011422's Avatar
    Sep 2003
    Genoa, Il
    What the hell is this 1.1 framework the setup program is asking me to install? It takes me to a link to like 15 different links about framework? Anyhelp??
    It's not what you buy............It's what you build
    Variable Bitrate vcbb5's Avatar
    Aug 2002
    Kansas
    My Mazda 3s
    My Mazda 3s on Car Domain
    [||||||||||||||||||--] (90%)
    Constant Bitrate Willy-Mach1's Avatar
    Mar 2005
    Laurel, Maryland
    it is most likely .NET Framework....if you have an internet connection in the car doing a Windows Update should get you what you need
    Progress: |##########| 99.99%
    - Tweaking and enjoying!!!! Never really done.....
    -= MachPuter Project =-
    -= MachPuter Project Worklog=-
    Sep 2003
    Genoa, Il
    Damnit, Its jsut not working!!! I've installed the link and its still not letting me install cf..WTF!!?!?!?! All I want to do is install a program!!!
    Raw Wave
    Jun 2004
    On the beach
    Check which sub version it needs .... I've found that 1.1 apps are very fussy about the version they need.
    Jul 2004
    NL, Druten
    http://windowsupdate.microsoft.com
    Select optional software updates, check Microsoft .NET Framework and press install..
    good luck!
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    or try to download using the link in fluxmedia.net
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  1. Is 1.1 USB ports ok for XM,GPS, Hauppauge
    By clean customs in forum Newbie
    Last Post: 01-23-2005, 01:59 PM
  2. New Release CENTRAFUSE 1.1
    By veetid in forum Centrafuse
    Last Post: 01-18-2005, 09:17 AM
  3. USB 1.1: What are the limits?
    By Dominik in forum General Hardware Discussion
    Last Post: 10-10-2004, 11:41 PM
  4. Stupidme, USB 1.1 Micro Hub
    By judoGTI in forum General Hardware Discussion
    Last Post: 08-22-2004, 06:42 AM
  5. are usb 2.0 devices able to work with usb 1.1 hubs?
    By chris in nh in forum General Hardware Discussion
    Last Post: 06-28-2004, 07:27 PM
